Global Health Status for Load Balanced Endpoints
I have two load balanced endpoints:
http://10.136.133.148
http://10.136.133.149
They run a service that listens on ports 35997 and 35998. Each endpoint also has an API at :8080/healthcheck that checks to make sure the service is working properly. The healthcheck for each endpoint is “global” for that endpoint. Meaning, the response to: http://10.136.133.148:8080/healthcheck represents the health of:
http://10.136.133.148:35997
and
http://10.136.133.148:35998
the way this is setup now, Caddy hits :8080/healthcheck twice every 10 seconds. Is there a way to apply the heath status of port 35997 to 35998 so I only run this heath check once every 10 seconds?
Here is my Caddyfile
my.hc1node.com:35997 {
        reverse_proxy http://10.136.133.148:35997 http://10.136.133.149:35997 {
                lb_policy random
                health_interval 10s
                health_timeout 5s
                health_uri /healthcheck
                health_port 8080
                health_status 2xx
my.hc1node.com:35998 {
        reverse_proxy http://10.136.133.148:35998 http://10.136.133.149:35998 {
                lb_policy random
                health_interval 10s
                health_timeout 5s
                health_port 8080
                health_status 2xx
No errors are produced
Distributor ID: Ubuntu
Description: Ubuntu 22.10
Release: 22.10
Codename: kinetic
DigitalOcean: 2vcpu-2gb-intel,
systemctl start caddy
Type=notify
PrivateDevices=yes
                lb_policy random
                health_interval 10s
                health_timeout 5s
                health_port 8080
                health_status 2xx
                lb_policy random
                health_interval 10s
                health_timeout 5s
                health_port 8080
                health_status 2xx
Active health checks are designed to be per-upstream-address. What you’re asking for isn’t a supported usecase. First time I’ve ever heard anyone trying to do this as well, so it’s not something we designed for.
Why is it a problem to do health checks more than every 10 seconds? Health checks should always be super fast/instantaneous to run.
Understood. I think I have a unique use case where the endpoint is a node in a blockchain. The node is not always in sync due to latency across the network. This can cause the node health check to respond slower than expected. Maybe I need to rethink how I do the health check so it’s always fast.
Thank you for looking at my question.
