Caddy v2 / Debian package
caddy run + json file
Linux Debian
curl localhost:2019/load -X POST -H "Content-Type: application/json" -d @nagios_formated.json
"apps": {
"http": {
"servers": {
"srv0": {
"listen": [
":443"
"logs": {
"logger_names": {
"caddy.test.local": "log0"
"routes": [
"handle": [
"handler": "subroute",
"routes": [
"handle": [
"handler": "reverse_proxy",
"upstreams": [
"dial": "10.13.102.50:80"
"headers": {
"request": {
"add": {
"CENTREON":["{SSL_CLIENT_SAN_Email_0}"]
"match": [
"host": [
"caddy.test.local"
"terminal": true
"tls_connection_policies": [
"certificate_selection": {
"any_tag": [
"cert0"
"client_authentication": {
"mode": "require_and_verify",
"trusted_ca_certs": [
"MIIDtzCCAp+gAwIBAgIQDOfg5RfYRv6P5WD8G/AwOTANBgkqhkiG9w0BAQUFADBlMQswCQYDVQQGEwJVUzEVMBMGA1UEChMMRGlnaUNlcnQgSW5jMRkwFwYDVQQLExB3d3cuZGlnaWNlcnQuY29tMSQwIgYDVQQDExtEaWdpQ2VydCBBc3N1cmVkIElEIFJvb3QgQ0EwHhcNMDYxMTEwMDAwMDAwWhcNMzExMTEwMDAwMDAwWjBlMQswCQYDVQQGEwJVUzEVMBMGA1UEChMMRGlnaUNlcnQgSW5jMRkwFwYDVQQLExB3d3cuZGlnaWNlcnQuY29tMSQwIgYDVQQDExtEaWdpQ2VydCBBc3N1cmVkIElEIFJvb3QgQ0EwggEiMA0GCSqGSIb3DQEBAQUAA4IBDwAwggEKAoIBAQCtDhXO5EOAXLGH87dg+XESpa7cJpSIqvTO9SA5KFhgDPiA2qkVlTJhPLWxKISKityfCgyDF3qPkKyK53lTXDGEKvYPmDI2dsze3Tyoou9q+yHyUmHfnyDXH+Kx2f4YZNISW1/5WBg1vEfNoTb5a3/UsDg+wRvDjDPZ2C8Y/igPs6eD1sNuRMBhNZYW/lmci3Zt1/GiSw0r/wty2p5g0I6QNcZ4VYcgoc/lbQrISXwxmDNsIumH0DJaoroTghHtORedmTpyoeb6pNnVFzF1roV9Iq4/AUaG9ih5yLHa5FcXxH4cDrC0kqZWs72yl+2qp/C3xag/lRbQ/6GW6whfGHdPAgMBAAGjYzBhMA4GA1UdDwEB/wQEAwIBhjAPBgNVHRMBAf8EBTADAQH/MB0GA1UdDgQWBBRF66Kv9JLLgjEtUYunpyGd823IDzAfBgNVHSMEGDAWgBRF66Kv9JLLgjEtUYunpyGd823IDzANBgkqhkiG9w0BAQUFAAOCAQEAog683+Lt8ONyc3pklL/3cmbYMuRCdWKuh+vy1dneVrOfzM4UKLkNl2BcEkxY5NM9g0lFWJc1aRqoR+pWxnmrEthngYTffwk8lOa4JiwgvT2zKIn3X/8i4peEH+ll74fg38FnSbNd67IJKusm7Xi+fT8r87cmNW1fiQG2SVufAQWbqz0lwcy2f8Lxb4bG+mRo64EtlOtCt/qMHt1i8b5QZ7dsvfPxH2sMNgcWfzd8qVttevESRmCD1ycEvkvOl77DZypoEd+A5wwzZr8TDRRu838fYxAe+o0bJW1sj6W3YQGx0qMmoRBxna3iw/nDmVG3KwcIzi7mULKn+gpFL6Lw8g=="
"match": {
"sni": [
"caddy.test.local"
"protocol_min": "tls1.2"
"tls": {
"certificates": {
"load_files": [
"certificate": "/etc/caddy/ssl/caddy_test.local.cer",
"key": "/etc/caddy/ssl/caddy_test.local.key",
"tags": [
"cert0"
"logging": {
"logs": {
"default": {
"exclude": [
"http.log.access.log0"
"level":"DEBUG"
"log0": {
"include": [
"level":"DEBUG",
"writer": {
"filename": "/var/log/access.log",
"output": "file"
CENTREON:[{SSL_CLIENT_SAN_Email_0}]
Hi,
I’m setting up a reverse proxy to acces an application. I want ton control acces with client certs on the caddy revese proxy (working)
Now I want to pass some variable to my upstream server : In need to read the {SSL_CLIENT_SAN_Email_0}" from my client cert and send it to my server.
No error, phpinfo display a null value :
$_SERVER['HTTP_CENTREON'] *no value*
Tried different values :
- CENTREON:[{SSL_CLIENT_SAN_Email_0}]
- CENTREON:[{env.SSL_CLIENT_SAN_Email_0}]
Same thing.
If I put a mail hardcoded, it is working, php is receiving the correct value :
- CENTREON:[“test@email.com”]
Dis someone have an idea on how to set it up ?
Thanks in advance
Juju
