We’re running a virtual host and want to ensure TLS for all our domains. This is our current configuration, and it works flawlessly (still amazed at how simple this was):
The problem: We aren’t able to redirect www.* traffic to the root domain in a generic way (e.g. a request to www.example.com should go to go example.com, so we don’t have to maintain two certificates per domain).
What we have tried (roughly):
www.* {
redir https://{root}{uri} # this clearly won't work, just including to illustrate thought process
gzip
proxy / {
upstream http://server_live:{$PORT}
tls contact@redacted.net {
ask http://server_live/validate-domain
I don’t expect this configuration to work for several reasons, but I hope it illustrates what we’re trying to do, and that someone knows how to achieve the behaviour we want
The limiting factor here is that there’s no method available via Caddyfile to take an arbitrary detail of the request and transform it for use in a later function like a redirect.
If you are redirecting away from one host and to another, you will need to know the full destination or be able to build it out of placeholders.
There’s a heavily work-in-progress PR over at the Github page for Caddyfile-wide “if” statements which might possibly one day support arbitrarily extracting this information via regex.
Have a certificate for both www.* and the root domain
Wildcard certificates
The first option seems a little excessive and would double our issuance, bringing us closer to the rate limit (which we’re already slightly concerned about).
The second option seems more appropriate to me (if it works like I understand it); do you know if a wildcard certificate would cover both “example.com” and “www.example.com”?
The wildcards Caddy will requisition won’t, I don’t think, cover both *.example.com and example.com.
If the registered domains you’re getting certificates for are distinct, I don’t think you’re likely to run into the rate limits… The biggest one is 20/week for the same registered domain (and 5 duplicates/week).
Ah, probably not worth messing with wildcards for this purpose then (although we will add subdomains eventually)
Concerning rate limit we were mostly concerned with:
After 10 certificates are successfully obtained, new certificate challenges will not happen until 10 minutes after the last successful challenge.
We could potentially run into scenarios where a lot of new domains (or subdomains) require new certificates at the same time, clogging us up for a bit. Probably not likely to happen in the near term, but I like sleeping easy
Anyway, thanks a ton for the help - we should be able to work something out by ourselves from here
Actually, I might be wrong about that. Docs don’t actually say that’s the case (in fact, they specify that the ask endpoint works in addition to the rate limits), but I’m pretty sure I recall it got around it… Another thread recently somewhere was talking about it, I’ll see if I can find it.
