mydomain.testcorp.ovh {
root * /var/www/mydomain.testcorp.ovh/
output file /var/log/caddy/mydomain.testcorp.ovh.log {
roll_size 10MiB
roll_keep 10
header / {
# HSTS (ngx_http_headers_module is required) (15768000 seconds = 6 months)
Strict-Transport-Security max-age=15768000
# Prevent IE and Chrome from incorrectly detecting non-scripts as scripts
# Block site from being framed
X-Frame-Options DENY
# Block pages from loading when they detect reflected XSS attacks
I have 3 questions :
In the documentation, it says to run command “caddy file-server --domain mydomain.testcorp.ovh” to have HTTPS enabled. I was expecting this command to go in the background instead of “beeing stuck” in front of the terminal. Is it normal?
Source : HTTPS quick-start — Caddy Documentation
It seems like there is 0 logs about what is going on.
I’ve written directive “output file /var/log/caddy/mydomain.testcorp.ovh.log” but it provides 0 logs.
Is it normal?
The directive for changing the root path is not working. As I have 0 logs I don’t know what is happening. Curl and browsers are having 404, I’ve tried multiples scenarios (w/o path, w/ path index.html).
Source : root (Caddyfile directive) — Caddy Documentation
Please upgrade to v2.4.5! You’re using a pretty old version at this point.
If you’re using the systemd service, then you shouldn’t be using the caddy file-server command. Those will be in conflict.
You’re using a path matcher of / here, which will only match requests to exactly / and nothing else. Path matching is exact in Caddy v2. To make those headers get sent on all requests, remove the /.
That command is just one example of a way to run Caddy. You shouldn’t also run it if you’re running Caddy another way.
The caddy file-server command is only meant to quickly run a one-off file server, like for quickly testing a static site you’re developing locally. For long-term use, it’s not ideal, and using the systemd service is much better.
Please read these docs which explain how to use Caddy when run as a service, including how to see your logs:
With the log directive, that only outputs access logs, and not the rest of Caddy’s logs (startup, errors, cert maintenance, etc)
I don’t think the problem is with the directive. Does the caddy user (which the service runs as) have permissions to read the files from /var/www/mydomain.testcorp.ovh? Make sure the file permissions are correctly set.
After double checking the command "caddy file-server --domain mydomain.testcorp.ovh was indeed adding confusion with CaddyFile.
I don’t use it anymore and it works better.
One more question: HTTPS is still not working.
IPV6 is disabled.
I’ve tried different possibilities for the host section (mydomain is actually another domain which is resolvable) :
All generate the same error :
run: adapting config using caddyfile: subject does not qualify for certificate:
