rainyu
(余雨)
April 10, 2022, 7:33am
#1
I have a vue+java project. When the front-end accesses the back-end interface, I can’t access the 404. This project is normal on nginx. After migrating to caddy, there is a problem. I hope you can guide me to configure the front and rear cross sections. domain problem.Below is my existing configuration.
http://localhost:2100 {
encode zstd gzip
root * /home/dist
file_server browse
reverse_proxy /api/* http://192.168.1.6:8000 {
header_down Access-Control-Allow-Headers *
header_down Access-Control-Allow-Origin *
Please fill out the help topic template. We can’t help unless you fill it out and provide more detailed information.
rainyu
(余雨)
April 11, 2022, 1:41am
#3
Caddy v2
In virtual machine with Ubuntu20.04
Ubuntu20.04
caddy adapt --config /path/Caddyfile
systemd
encode zstd gzip
root * /home/dist
file_server browse
Always 404 when my frontend calls the backend interface
rainyu:
Caddy v2
What version, exactly ?
Show example requests.
rainyu:
Error messages and/or full log output:
Show your logs.
Please completely fill out the help topic template, we can’t help unless you help us help you.
system
(system)
closed
May 10, 2022, 7:34am
#5
