JapArt
(JapArt)
#1
1. My Caddy version (2 devel):
I want to try Caddy for Rails applications. There is zero information on how to configure this. I only have a Caddyfile from v1:
https://domainname.co.uk {
root /path/to/app/root
log /path/to/app/root/log/access.log
tls webmaster@domainname.co.uk
proxy / unix:///path/to/your/capistrano/deployment/shared/tmp/sockets/appname-puma.sock {
proxy_header Connection {>Connection}
proxy_header Upgrade {>Upgrade}
How can I translate this to v2?
Thank you!
Amazon EC2
Ubuntu 18.04.3 LTS (GNU/Linux 4.15.0-1052-aws x86_64)
Hi @JapArt, welcome to the Caddy community.
v2 docs can be a bit overwhelming in some points right now, as finalizing those will be one of the later steps in getting v2 out of beta.
If you want to go to a v2 Caddyfile, the directives for those are outlined here:
Home · caddyserver/caddy Wiki · GitHub
For the unix socket, the syntax is slightly different:
If you have a Unix socket, use an address in the form unix//path/to/socket
—Home · caddyserver/caddy Wiki · GitHub
It’s noted in the php_fastcgi
section, but applies to any upstream.
system
(system)
closed
#3
