Frankenphp daemon keeps exiting
frankenphp systemd daemon keeps exiting.
Aug 19 14:07:18 dev frankenphp[9273]: {"level":"debug","ts":1724076438.6005154,"logger":"http.stdlib","msg":"http: TLS handshake error from 82.180.154.41:53332: local error: tls: bad record MAC"}
FrankenPHP v1.2.3 PHP 8.3.10 Caddy v2.8.4
systemctl start frankenphp
systemd
Description=FrankenPHP Server
Restart=on-failure
Type=notify
User=frankenphp
Group=frankenphp
ExecStartPre=/usr/bin/frankenphp validate --config /etc/frankenphp/Caddyfile
ExecStart=/usr/bin/frankenphp run --environ --config /etc/frankenphp/Caddyfile
ExecReload=/usr/bin/frankenphp reload --config /etc/frankenphp/Caddyfile --force
Environment=PHP_INI_SCAN_DIR=/etc/php.d/
    # Enable FrankenPHP
    frankenphp
    # Logging
        output stderr
        level DEBUG
dev.sportch.co.uk {
    # Enable compression (optional)
    encode zstd br gzip
    root * /var/www/html/SportchLegacyApp
    # Define a route for handling requests
    route {
        # Security: Hide specific paths
        @hide path /.env *.sql *.template /gtscripts/* *.txt *.md /random /support vapi/ var/ /support /system.* /lib
        respond @hide 404
        # Execute PHP files
        php_server
        # Rewrite subfolder requests for screenscrapers
        rewrite /ladder/* /ladder/index.php
        rewrite /manager/* /manager/index.php
         # Add WebSocket support
        @websocket {
            header Connection *Upgrade*
            header Upgrade websocket
        reverse_proxy @websocket localhost:5502
That’s not a fatal log. It just means some client failed the TLS handshake, likely some bot/crawler. Is that really the last thing in the logs before it exits?
Please share more than just one log line. Be more specific. Give us more to work with.
You’ll need to ask on the FrankenPHP github repo.
How do I know when it exited?
Well, you tell me. How do you know it exited at all? What’s your evidence of that? I don’t understand.
The website was working. The website stopped working. The frankenphp service wasn’t running. Starting it fixed the website.
Okay, then find the logs from just before you started it back up.
I’ll have to wait till it happens again. I didn’t note the time and there’s reams of log data being generated.
