- prod1
- dev1
Both instances are in Ubuntu guests running under Hyper-V
- prod1
systemd
- dev1
docker-compose
#prod1
sudo systemctl enable --now caddy
#dev1
docker-compose --profile main start
#prod1
Type=notify
#dev1
image: caddy:2
- main
- caddy_data:/data
- caddy_config:/config
focalboard:
image: mattermost/focalboard
profiles:
- main
- focalboard
- main
- focalboard
- focalboard_data:/data
wiki:
image: requarks/wiki:2
profiles:
- main
- wiki
depends_on:
- wiki_db
env_file:
- ./wiki.env
- main
- wiki
wiki_db:
image: postgres
profiles:
- main
- wiki
env_file:
- ./wiki.env
- wiki
- wiki_db_data:/var/lib/postgresql/data
rocket_chat:
image: rocket.chat
profiles:
- main
- rocket_chat
depends_on:
- rocket_chat_db
env_file:
- ./rocket_chat.env
- main
- rocket_chat
rocket_chat_db:
image: bitnami/mongodb
profiles:
- main
- rocket_chat
env_file: ./rocket_chat.env
- rocket_chat
- rocket_chat_data:/bitnami/mongodb
caddy_data:
external: true
caddy_config:
wiki_db_data:
external: true
rocket_chat_data:
external: true
focalboard_data:
external: true
main:
wiki:
rocket_chat:
focalboard:
#prod1
wiki.riverbedranch.org {
reverse_proxy localhost:2080
riverbedranch.dev {
reverse_proxy 10.0.1.80:80
#dev1
#:80, :443 {
# respond "This is 10.0.1.80"
riverbedranch.dev {
reverse_proxy focalboard:8000
#kanban.riverbedranch.dev {
# reverse_proxy focalboard:8000
I’m hosting a server at my house with Hyper-V installed. I have one IP, and decided that forwarding traffic to riverbedranch.dev
from prod1 to dev1. If I uncomment the :80, :443 ....
entry on dev1 I get the response.
# prod1
Jul 23 16: 18: 31 riverbedranch.org caddy[462346]: {
"level": "error",
"ts": 1658614711.0829048,
"logger": "http.log.error",
"msg": "dial tcp 10.0.1.80:80: connect: connection refused",
"request": {
"remote_ip": "216.147.121.173",
"remote_port": "65349",
"proto": "HTTP/2.0",
"method": "GET",
"host": "riverbedranch.dev",
"uri": "/favicon.ico",
"headers": {
"Sec-Fetch-Mode": ["no-cors"],
"Sec-Fetch-Site": ["same-origin"],
"Sec-Gpc": ["1"],
"Pragma": ["no-cache"],
"Accept": ["image/avif,image/webp,*/*"],
"Accept-Language": ["en-US,en;q=0.5"],
"Referer": ["https://riverbedranch.dev/favicon.ico"],
"Dnt": ["1"],
"Te": ["trailers"],
"User-Agent": ["Mozilla/5.0 (X11; Linux x86_64; rv:102.0) Gecko/20100101 Firefox/102.0"],
"Accept-Encoding": ["gzip, deflate, br"],
"Sec-Fetch-Dest": ["image"],
"Cache-Control": ["no-cache"]
"tls": {
"resumed": false,
"version": 772,
"cipher_suite": 4865,
"proto": "h2",
"server_name": "riverbedranch.dev"
"duration": 0.0016644,
"status": 502,
"err_id": "rs7v0n7a8",
"err_trace": "reverseproxy.statusError (reverseproxy.go:1184)"
I’ve tried setting X-Forwarded-Host
and other things like trusted_proxies
but, I’m not sure if I’m doing it correctly.
