First Caddy website
I have it too
When I go to a website it appears
When I use VPS to access the site, it doesn’t appear, please help I fix the error
Same questions:
Please don’t hijack someone else’s help post, open your own. I split your comment into its own thread.
How I am not the website owner
You’re gonna need to use a lot more words than that.
I can’t help you if you don’t help yourself.
I’m not the one who created that website, but when I normally access it, I can’t access it now
I don’t know how to fix it
Point your domain’s A/AAAA DNS records at this machine.
Upload your site’s files to /var/www/html.
Edit your Caddyfile at /etc/caddy/Caddyfile:
Replace :80 with your domain name
Change the site root to /var/www/html
Reload the configuration: systemctl reload caddy
Visit your site!
Usually used for its creator, right?
Okay, then contact the person who set it up.
:man_facepalming:
I don’t even know how to contact person who set it up.
They don’t leave anything for communication
Well, I can’t help you either. Caddy is just a program someone can run on their server to serve their website. We have no contact with users unless they reach out to us.
