Run caddy with filemanager plugins on winserver.
filemanager scope is no limit. Admin login and modify scope on the web. Get access to drive C. Can delete winsystem.
How to limit filemanager and caddy to the scope?
Thanks.
Q2: How to add multiple paths? Folders scattered across multiple physical disks.
You can set the scope by going to Settings → User Settings and change the Scope of your user. Each user can only have a scope and not multiple scopes. You could try using symlinks to have multiple paths.
