I’m running a Caddy webserver with php_fpm. I have a rewrite set where if the requested path
doesn’t exist, it tries path.php
, so I can have cleaner looking URIs. However, it seems the FastCGI matching is done based on the path and not the real filename, so /contact is not run through FastCGI. How do I make it so that both *.php
and [^\ .]*
(any requests with no extension) get passed to FastCGI?
Hi @VirtualDXS,
Could you share your Caddyfile so we can see what kind of changes would need to be made?
The fastcgi
directive is directed by the base path and the ext
subdirective. It operates on the URI, including rewrites, and will try to fallback to an index specified by the index
subdirective. If the URI begins with the base path and ends with the value specified by ext
, it will be sent to FastCGI.
The available php
preset specifies ext .php
and index index.php
, so if you’re using that, and /contact
has no index.php
, and you’re not rewriting to a URI that ends in .php
, it wouldn’t be forwarded.
Without the php
preset, all requests would be forwarded to FastCGI. You could also rewrite /contact /contact.php
