rinomnur
(Rino M Nur)
1
How can i load balance my fastcgi to backend for example like nginx
upstream backend {
server 127.0.0.1:9000 weight=4000 max_fails=5 fail_timeout=5;
server 127.0.0.1:9001 weight=4000 max_fails=5 fail_timeout=5;
location ~ .php$ {
fastcgi_split_path_info ^(.+.php)(/.+)$;
fastcgi_read_timeout 300;
fastcgi_pass backend;
1. My Caddy version (1.0.3
/usr/local/bin/caddy -conf=caddy.file -email=entuy@gmail.com -log=/data/caddy.log -cpu=90% -quic
Redhat 7
Thanks All,
Rino
matt
(Matt Holt)
2
Caddy 2 can do this
You can use the php_fastcgi directive, which takes the same syntax as the reverse_proxy directive:
Notice how you can define multiple backends and load balancing policies and health checks.
Please try it out!
rinomnur
(Rino M Nur)
3
Hi Matt,
Thanks for the reply, then if my case i have 2 node php-fpm server let say :
127.0.0.1:9000
127.0.0.1:9001
then the config will be :
matcher phpFiles {
path *.php
reverse_proxy match:phpFiles php-fpm:9000 {
transport fastcgi {
split .php
reverse_proxy phpFiles backend {
# backends
to 127.0.0.1:9000, 127.0.0.1:9001
# load balancing
lb_policy loadbalance loadbalance
lb_try_duration 10
lb_try_interval 5
Am i right ?
Please give me an example.
Thanks
matt
(Matt Holt)
4
Why not just use the php_fastcgi
directive? Then it’s just one line or two.
Because it’s not written in the doc
transport fastcgi {
split .php
matt
(Matt Holt)
6
@al-caddyserver
You mean this?
Thus your config would be:
php_fastcgi 127.0.0.1:9000 127.0.0.1:9001
system
(system)
Closed
7
