Good Evening all,
I new to all this and was hoping to get some advice.
I’m running caddy in ubuntu 18.04.1 but really seem to be struggling.
when typing in this command sudo caddy -host mydomain.co.uk get this 403 error :
please help!
Good Evening all,
please help!
Hi @MrMiles156, welcome to the Caddy community.
mydomain.co.uk
does not have any ‘A’ records, so a validated certificate can’t be issued by LetsEncrypt.
If you were just using it as an example, I’d suggest using example.com
instead, or mysite.example
, as these domains are reserved specifically for this purpose.
The partially-obscured domain in the image you provided does have an ‘A’ record, but attempts to access it result in a peculiar redirect chain:
HTTP/1.1 302 Found
Connection: close
Pragma: no-cache
cache-control: no-cache
HTTP/1.1 302 Found
Connection: close
Pragma: no-cache
HTTP/1.1 301 Moved Permanently
Server: nginx/1.12.2
Date: Fri, 28 Sep 2018 06:33:50 GMT
Content-Type: text/html; charset=utf-8
Connection: close
The redacted final Location header points to an IP address that does not match the IP address given for the domain itself. LetsEncrypt will not follow this redirect - Caddy has to answer, and it must answer when directly accessed at the domain name you’re attempting to requisition a certificate for. Also, the final Location doesn’t seem to be responding (connection attempts time out from my end).
