1. Output of caddy version
./caddy-dav version
I want to run Caddy as a WebDAV server. I’ve built with the DAV module, and am trying to set up authn/authz appropriately. I’d like one set of accounts to have access to all resources and grant some accounts access to subdirectories for the server.
For example, I’d like to have rootuser
have access to everything under /
, and auser
under /a
Running on debian testing at the moment, but also seen the behavior on Arch.
./caddy-dav run --config Caddyfile
c. My complete Caddy config:
auto_https off
(commonuser) {
rootuser $2a$14$4hhw4M3lnbJsmAzZQ7ulWerfPVYweV9gx5Cfd2eBJZhQv/cOFb0fG
:7890 {
output stderr
format console
root * /tmp/caddydav/root
route {
handle /a/* {
basicauth bcrypt "a" {
import commonuser
auser $2a$14$4hhw4M3lnbJsmAzZQ7ulWerfPVYweV9gx5Cfd2eBJZhQv/cOFb0fG
handle /* {
basicauth bcrypt "root" {
import commonuser
@get method GET
file_server @get {
browse
webdav
Note that the password for both accounts is testing123
I expect that the user auser
has access to only /a/
, but rootuser
has access to everything. rootuser
works, but auser
does not.
curl -u rootuser:testing123 -v http://localhost:7890/a/index.html
* Trying ::1:7890...
* Trying 127.0.0.1:7890...
* Connected to localhost (127.0.0.1) port 7890 (#0)
* Server auth using Basic with user 'rootuser'
> GET /a/index.html HTTP/1.1
> Host: localhost:7890
> Authorization: Basic cm9vdHVzZXI6dGVzdGluZzEyMw==
> User-Agent: curl/7.74.0
> Referer:
< HTTP/1.1 200 OK
< Accept-Ranges: bytes
< Content-Length: 10
< Content-Type: text/html; charset=utf-8
< Etag: "rojke1a"
< Last-Modified: Sun, 15 Jan 2023 19:20:25 GMT
< Server: Caddy
< Date: Sun, 15 Jan 2023 21:00:29 GMT
this is a
curl -u auser:testing123 -v http://localhost:7890/a/index.html
* Server auth using Basic with user 'auser'
> Authorization: Basic YXVzZXI6dGVzdGluZzEyMw==
> Referer:
< HTTP/1.1 401 Unauthorized
< Server: Caddy
* Authentication problem. Ignoring this.
< Www-Authenticate: Basic realm="root"
< Date: Sun, 15 Jan 2023 21:12:55 GMT
< Content-Length: 0
Note that it requires realm root
, but I understand that handle
blocks should be mutually exclusive. Is there something I am not understanding about this?
2023/01/15 21:14:27.101 INFO using provided configuration {"config_file": "Caddyfile", "config_adapter": ""}
2023/01/15 21:14:27.103 INFO admin admin endpoint started {"address": "localhost:2019", "enforce_origin": false, "origins": ["//localhost:2019", "//[::1]:2019", "//127.0.0.1:2019"]}
2023/01/15 21:14:27.103 WARN http automatic HTTPS is completely disabled for server {"server_name": "srv0"}
2023/01/15 21:14:27.103 INFO tls.cache.maintenance started background certificate maintenance {"cache": "0xc000960e00"}
2023/01/15 21:14:27.103 DEBUG http starting server loop {"address": "[::]:7890", "tls": false, "http3": false}
2023/01/15 21:14:27.103 INFO http.log server running {"name": "srv0", "protocols": ["h1", "h2", "h3"]}
2023/01/15 21:14:27.103 INFO tls cleaning storage unit {"description": "FileStorage:/home/user/.local/share/caddy"}
2023/01/15 21:14:27.103 INFO tls finished cleaning storage units
2023/01/15 21:14:27.103 INFO autosaved config (load with --resume flag) {"file": "/home/user/.config/caddy/autosave.json"}
2023/01/15 21:14:27.103 INFO serving initial configuration
2023/01/15 21:14:39.123 DEBUG http.log.error.log0 not authenticated {"request": {"remote_ip": "127.0.0.1", "remote_port": "45252", "proto": "HTTP/1.1", "method": "GET", "host": "localhost:7890", "uri": "/a/index.html", "headers": {"User-Agent": ["curl/7.74.0"], "Accept": ["*/*"], "Referer": [""], "Authorization": []}}, "duration": 1.594662275, "status": 401, "err_id": "885f5qwp8", "err_trace": "caddyauth.Authentication.ServeHTTP (caddyauth.go:88)"}
2023/01/15 21:14:39.123 ERROR http.log.access.log0 handled request {"request": {"remote_ip": "127.0.0.1", "remote_port": "45252", "proto": "HTTP/1.1", "method": "GET", "host": "localhost:7890", "uri": "/a/index.html", "headers": {"Referer": [""], "Authorization": [], "User-Agent": ["curl/7.74.0"], "Accept": ["*/*"]}}, "user_id": "auser", "duration": 1.594662275, "size": 0, "status": 401, "resp_headers": {"Server": ["Caddy"], "Www-Authenticate": ["Basic realm=\"root\""]}}
- Read the docs on
handle
blocks repeatedly. - Tried both
and no path on the fall-through handle block.
