Can Caddy syntax evaluate a conditional based on a environment variable?
For example:
if( {$DEV} === true ) {
root /var/www/dev
The environment variable $DEV
is equal to true
For example:
root /var/www/dev
is equal to true
No, the Caddyfile is not really programmable. (And that’s how I like it, personally.)
I’m bending my own preferences a bit with this PR: https://github.com/mholt/caddy/pull/1948
If that PR gets merged, then what you want to do may be possible, but I am not sure if it will work properly.
For now, and even in the future, probably better to set an environment variable containing the value of your root path: root {$SITE_ROOT}
or something.
You could use if
functionality of existing directives like redir
and rewrite
, though, as env vars can be used in place of any Caddyfile token: The Caddyfile — Caddy Documentation
For example, this should effectively serve your site from /var/www/dev
when DEV=true
in your environment, and will serve from /var/www/prod
otherwise:
root /var/www
rewrite {
if {$DEV} is true
to /dev{uri}
rewrite {
if {$DEV} not true
to /prod{uri}
