woez.dk {
reverse_proxy localhost:8096
The error happens everytime i play a video in Jellyfin or i stop a video, if i ignore it and just keep watching videos, then it seems caddy stops working. It still running but is not forwarding anymore.
2023/02/08 06:41:50.912 ←[31mERROR←[0m http.handlers.reverse_proxy aborting with incomplete response {"error": "context canceled"}
2023/02/08 06:41:54.773 ←[31mERROR←[0m http.handlers.reverse_proxy aborting with incomplete response {"error": "stream 292 canceled with error code 268"}
Nothing besides searching to see if i could find somebody if similar problem.
That is definitely obscure. But yeah, it looks like it’s caused by something strange with the backend and/or the Go standard library and its interaction with it.
I’m somewhat acquainted with a Jellyfin dev, let me see if any of them have a clue. They’re pretty smart about stuff
Well, the error apparently comes from the remote (Jellyfin in this case) doing something with the connection that Caddy (or its underlying Go standard library) isn’t expecting. Caddy itself doesn’t have code that emits that error, so I think it originates from the Go standard library, but I’m not sure what is causing it to happen in the first place. It’s basically something from Go itself or from Jellyfin, or the interaction between the two.
Can you make it minimally reproducible? I have a Jellyfin setup so I would be willing to try.
Again i have to say i am no expert at all, just learning as i go!
I just downloaded Jellyfin, installed it, setup the admin user, added a library, nothing els has been done to Jellyfin.
I then proceeded to portforward 80, 443 and 8086 in my router and in the windows firewall.
Then i went to my domain host and forwarded it to my ip.
Then i grabbed Caddy, extraced it to a folder on c:\desktop\Caddy, made the very simple config file as shown above and created a “caddystart.bat” and added a shortcut for that in “shell:startup”.
Bat file:
“cd C:\Users\EZSERVER\Desktop\Caddy
caddy run”
Thats all i have done so far, not sure if thats what you mean by reproduce.
It is still putting out the error in caddy everytime i press play on a movie/video and when i exit the movie/video, but now Caddy seems to keep working and dosent stop forwarding the traffic which is good.
I can live with the error popping up, as long as it keeps working, i just wanted to post it to you guys to see if i have done anything wrong.
