1. My Caddy version (caddy -version
root@Serviceflow-inlets:~# curl https://getcaddy.com | bash -s personal
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
100 7380 100 7380 0 0 32800 0 --:–:-- --:–:-- --:–:-- 32654
Downloading Caddy for linux/amd64 (personal license)…
Download verification OK
Extracting…
Putting caddy in /usr/local/bin (may require password)
Caddy v1.0.4 (h1:wwuGSkUHo6RZ3oMpeTt7J09WBB87X5o+IZN4dKehcQE=)
Successfully installed
/usr/local/bin/caddy run --config /etc/caddy/Caddyfile --adapter caddyfile --resume --environ
OS, relevant versions, systemd? docker? etc.
root@Serviceflow-inlets:~# lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 18.04.4 LTS
Release: 18.04
Codename: bionic
Running it has systemd
root@Serviceflow-inlets:~# systemctl status caddy
● caddy.service - Caddy Web Server
Active: failed (Result: exit-code) since Thu 2020-02-13 14:15:19 UTC; 4s ago
Process: 7472 ExecStart=/usr/local/bin/caddy run --config /etc/caddy/Caddyfile --adapter caddyfile --resume --environ (code=exited, status=1/FAILURE)
Main PID: 7472 (code=exited, status=1/FAILURE)
Feb 13 14:15:18 Serviceflow-inlets systemd[1]: Started Caddy Web Server.
Feb 13 14:15:19 Serviceflow-inlets caddy[7472]: 2020/02/13 14:15:19 args:2 - Error during parsing: Unknown directive 'run'
Feb 13 14:15:19 Serviceflow-inlets systemd[1]: caddy.service: Main process exited, code=exited, status=1/FAILURE
Feb 13 14:15:19 Serviceflow-inlets systemd[1]: caddy.service: Failed with result 'exit-code'.```
#### d. My complete Caddyfile:
root@Serviceflow-inlets:~# cat /etc/systemd/system/caddy.service
Description=Caddy Web Server
After=network.target
ExecReload=/usr/local/bin/caddy reload --config /etc/caddy/Caddyfile --adapter caddyfile
### 3. The problem I'm having:
I'm not able to start caddy using the below command
Below file is also empty
root@Serviceflow-inlets:~# cd /etc/ca
ca-certificates/ calendar/
### 4. Error messages and/or full log output:
Don't know where is log file. Checked in ```/var/log/``` didn't find anything there
