1. Caddy version
(v2.3.0 h1:fnrqJLa3G5vfxcxmOH/+kJOcunPLhSBnjgIvjXV/QTA=
running it as a service to run my application which is also running as a service using my subdomain at https://accounting.bosc.co.tz (my domain name is bosc.co.tz)
caddy.service - Caddy
Loaded: loaded (/lib/systemd/system/caddy.service; enabled; vendor preset: enabled)
Active: active (running) since Tue 2022-02-01 15:56:47 UTC; 1 day 4h ago
ubuntu 18.04 , hosted vps
caddy restart
caddy reload
systemcmtl -l status caddy
The Caddyfile is an easy way to configure your Caddy web server.
# domain name.
root * /usr/share/caddy
reverse_proxy localhost:8080
# php_fastcgi localhost:9000
3. The problem Iâm having:
trying to access site/application at
https://accounting.bosc.co.tz and get error as below only on firefox , On all other browsers is opening without any problem. This problem only started recently , application has been running for one year now without any issue like this before on all browsers , but suddenly we experience this only on firefox
Secure Connection Failed
An error occurred during a connection to accounting.bosc.co.tz. Peerâs Certificate has been revoked.
Error code: SEC_ERROR_REVOKED_CERTIFICATE
i have tried
caddy restart and
caddy reload to no avail
am afraid of deleting caddy resource folder as mentioned on other articles to force certificate regeneration as am not sure if the system will run again or not as this hosted application is used by many users already and have never tried it before so i cant experiment on production server directly
you can access application and reproduce error on firefox here by accessing
