Subject does not qualify for certificate
Error: adapting config using caddyfile: subject does not qualify for certificate: '{env.SSLCERTIFICATE}'
v2.6.4
I installed it using docker following a guide
I’m using Synology and docker
sudo docker-compose -f docker-compose_bitwarden-caddy.yml up
#Docker-compose file for Vaultwarden proxied by caddy 2.0
version: "3"
vaultwarden:
restart: always
# Dani Garcia image https://github.com/dani-garcia/bitwarden_rs
image: "vaultwarden/server:latest"
container_name: vaultwarden
# Timezone settings, important for Fail2ban to work
- TZ=Europe/Paris
# Logging connection attemps
- LOG_FILE=/data/bitwarden.log
- EXTENDED_LOGGING='true'
- LOG_LEVEL=warn
# Beef up a bit
- ROCKET_WORKERS=20
- WEBSOCKET_ENABLED='true'
# Hardening a bit
- SIGNUPS_ALLOWED='false'
- DISABLE_ADMIN_TOKEN='true'
#- ADMIN_TOKEN=YouRandomTokenHere
- SHOW_PASSWORD_HINT='false'
- DISABLE_ICON_DOWNLOAD='true'
#- SMTP_HOST=smtphost
#- SMTP_PORT=port
#- SMTP_SSL='true'
#- SMTP_FROM=address_from@domain.tld
#- SMTP_USERNAME=smtp_user_name
#- SMTP_PASSWORD=smtp_password
expose:
- "80"
- bitwarden_net
- /volume1/docker/bw-data:/data
restart: always
#Official Caddy 2.0 image
image: "caddy:latest"
container_name: Caddy_proxy
- TZ=Europe/Paris
- LOG_FILE=/data/logs/caddy.log
# Update this if SSL required according to the use of your own cert or requuest one from Let's Encrypt
- SSLCERTIFICATE=/volume1/docker/Cert/origincert.pem
- SSLKEY=/volume1/docker/Cert/private.pem
- ACMEE_AGREE='true'
- DOMAIN=domain
- EMAIL=email
#- 8443:443
- bitwarden_net
- ./caddy-data/config/Caddyfile:/etc/caddy/Caddyfile
- ./caddy-data/data:/data
- ./caddy-data/sites:/var/www/html
- Certfiles:/root/.caddy
Certfiles:
bitwarden_net:
# Caddyfile V2.0 config file
#Caddy on port 80 in container to bitwarden_rs private instance
#Use it if Caddy behind another reverse proxy such as the one embedded on Synology
output file {env.LOG_FILE}
level INFO
#roll_size 5MiB #Not working on Caddy V2.0.0 Beta20 https://caddyserver.com/docs/caddyfile/directives/log#log
#roll_keep 5 #Not working on Caddy V2.0.0 Beta20 https://caddyserver.com/docs/caddyfile/directives/log#log
encode zstd gzip
header / {
# Disallow the site to be rendered within a frame (clickjacking protection)
X-Frame-Options "DENY"
# Prevent search engines from indexing (optional)
X-Robots-Tag "none"
# Server name remove
-Server
# The negotiation endpoint is also proxied to Rocket
reverse_proxy /notifications/hub/negotiate vaultwarden:80
# Notifications redirected to the websockets server
reverse_proxy /notifications/hub vaultwarden:3012
# Proxy the Root directory to Rocket
reverse_proxy vaultwarden:80
#{env.DOMAIN}:443 {
# #Caddy on port 443 in container to bitwarden_rs private instance
# #Use it if Caddy exposed to the net
# #Doc about automatic HTTPS https://caddyserver.com/docs/automatic-https
# log {
# output file {env.LOG_FILE}
# level INFO
# #roll_size 5MiB #Not working on Caddy V2.0.0 Beta20 https://caddyserver.com/docs/caddyfile/directives/log#log
# #rool_keep 5 #Not working on Caddy V2.0.0 Beta20 https://caddyserver.com/docs/caddyfile/directives/log#log
# # Uncomment only one of the 2 lines. Depending if you provide your own cert or request one from Let's Encrypt
tls {env.SSLCERTIFICATE} {env.SSLKEY}
# tls {env.EMAIL}
# encode zstd gzip
# header / {
# # Enable HTTP Strict Transport Security (HSTS)
# Strict-Transport-Security "max-age=31536000;"
# # Enable cross-site filter (XSS) and tell browser to block detected attacks
# X-XSS-Protection "1; mode=block"
# # Disallow the site to be rendered within a frame (clickjacking protection)
# X-Frame-Options "DENY"
# # Prevent search engines from indexing (optional)
# X-Robots-Tag "none"
# # Server name remove
# -Server
# # The negotiation endpoint is also proxied to Rocket
# reverse_proxy /notifications/hub/negotiate vaultwarden:80
# # Notifications redirected to the websockets server
# reverse_proxy /notifications/hub vaultwarden:3012
# # Proxy the Root directory to Rocket
# reverse_proxy vaultwarden:80
