Error: adapting config using caddyfile for webdav
Cant make webdav to work.
Error: adapting config using caddyfile: parsing caddyfile tokens for 'route': unrecognized directive: webdav - are you sure your Caddyfile structure (nesting and braces) is correct?, at /etc/caddy/Caddyfile:18
curl -s1sLf ‘https://dl.cloudsmith.io/public/caddy/stable/gpg.key’ | sudo gpg --dearmor -o /usr/share/keyrings/caddy-stable-archive-keyring.gpg >> /dev/null 2>&1
curl -s1sLf ‘https://dl.cloudsmith.io/public/caddy/stable/debian.deb.txt’ | sudo tee /etc/apt/sources.list.d/caddy-stable.list >> /dev/null 2>&1
sudo apt update -y >> /dev/null 2>&1
sudo apt install caddy >> /dev/null 2>&1
Linux Host 6.8.0-51-generic #52-Ubuntu SMP PREEMPT_DYNAMIC Thu Dec 5 13:09:44 UTC 2024 x86_64 x86_64 x86_64 GNU/Linux
systemctl start caddy and systemctl reload caddy
Type=notify
		output file /var/log/caddy/caddy2.log
192.168.178.50 {
	    route {
		rewrite /dav /dav/
		basic_auth {
			dario REDACT
		webdav {
			prefix /dav
			root /
The webdav directive isn’t built-in. You need to build Caddy using xcaddy or use the download page.
Thanks for help, make it working with
caddy add-package github.com/mholt/caddy-webdav
