i use a reverse proxy for use with nextcloud.
as soon as I connect to my site, I get an error:
“ERR_SSL_PROTOCOL_ERROR”
<?xml version="1.0" encoding="UTF-8"?> root@deb-caddy:/etc/caddy# caddy run --config Caddyfile
2025/06/29 19:12:23.275 INFO maxprocs: Leaving GOMAXPROCS=1: CPU quota undefined
2025/06/29 19:12:23.275 INFO GOMEMLIMIT is updated {"package": "github.com/KimMachineGun/automemlimit/memlimit", "GOMEMLIMIT": 912911155, "previous": 9223372036854775807}
2025/06/29 19:12:23.276 INFO using config from file {"file": "Caddyfile"}
2025/06/29 19:12:23.276 INFO adapted config to JSON {"adapter": "caddyfile"}
2025/06/29 19:12:23.277 WARN Caddyfile input is not formatted; run 'caddy fmt --overwrite' to fix inconsistencies {"adapter": "caddyfile", "file": "Caddyfile", "line": 2}
2025/06/29 19:12:23.278 INFO admin admin endpoint started {"address": "localhost:2019", "enforce_origin": false, "origins": ["//localhost:2019", "//[::1]:2019", "//127.0.0.1:2019"]}
2025/06/29 19:12:23.278 INFO http.auto_https automatic HTTPS is completely disabled for server {"server_name": "srv0"}
2025/06/29 19:12:23.279 DEBUG http.auto_https adjusted config {"tls": {"automation":{"policies":[{}]}}, "http": {"servers":{"srv0":{"listen":[":443"],"routes":[{"handle":[{"handler":"subroute","routes":[{"hand
le":[{"handler":"static_response","headers":{"Location":["/remote.php/carddav"]},"status_code":301}],"match":[{"path":["/.well-known/carddav"]}]},{"handle":[{"handler":"static_response","headers":{"Location":["/
remote.php/caldav"]},"status_code":301}],"match":[{"path":["/.well-known/caldav"]}]},{"handle":[{"handler":"reverse_proxy","upstreams":[{"dial":"192.168.1.41:10443"}]}]}]}],"terminal":true}],"tls_connection_poli
cies":[{}],"automatic_https":{"disable":true}}}}}
2025/06/29 19:12:23.279 DEBUG http starting server loop {"address": "[::]:443", "tls": true, "http3": false}
2025/06/29 19:12:23.279 INFO http enabling HTTP/3 listener {"addr": ":443"}
2025/06/29 19:12:23.279 INFO http.log server running {"name": "srv0", "protocols": ["h1", "h2", "h3"]}
2025/06/29 19:12:23.279 DEBUG events event {"name": "started", "id": "dd55a681-e2fb-46a9-aff7-ff60b8c4063f", "origin": "", "data": null}
2025/06/29 19:12:23.279 INFO autosaved config (load with --resume flag) {"file": "/root/.config/caddy/autosave.json"}
2025/06/29 19:12:23.279 INFO serving initial configuration
2025/06/29 19:12:23.282 INFO tls storage cleaning happened too recently; skipping for now {"storage": "FileStorage:/root/.local/share/caddy", "instance": "760266ca-3588-4a8f-b4bd-321e4f94f692", "tr
y_again": "2025/06/30 19:12:23.282", "try_again_in": 86399.999999567}
2025/06/29 19:12:23.282 INFO tls finished cleaning storage units
2025/06/29 19:12:23.282 INFO tls.cache.maintenance started background certificate maintenance {"cache": "0xc0002cc600"}
2025/06/29 19:12:34.561 DEBUG events event {"name": "tls_get_certificate", "id": "2279e662-214f-4f23-ad92-8d93ae8d24a7", "origin": "tls", "data": {"client_hello":{"CipherSuites":[4865,4866,4867],"ServerName
":"mydomain.dedyn.io","SupportedCurves":[4588,29,23,24],"SupportedPoints":null,"SignatureSchemes":[1027,2052,1025,1283,2053,1281,2054,1537,513],"SupportedProtos":["h3"],"SupportedVersions":[772],"RemoteAddr":{"IP
":"192.168.1.16","Port":35323,"Zone":""},"LocalAddr":{"IP":"192.168.1.42","Port":443,"Zone":""}}}}
2025/06/29 19:12:34.563 DEBUG tls.handshake no matching certificates and no custom selection logic {"identifier": "mydomain.dedyn.io"}
2025/06/29 19:12:34.563 DEBUG tls.handshake no matching certificates and no custom selection logic {"identifier": "*.dedyn.io"}
v2.10.0
Debian Version 13
auto_https off
mydomain.dedyn.io {
reverse_proxy 192.168.1.41:10443
redir /.well-known/carddav /remote.php/carddav 301
redir /.well-known/caldav /remote.php/caldav 301
