dfang
(fang duan)
1
systemctl
ec2 ubuntu
sudo systemctl start caddy
paste full file contents here
how you will write caddy config for this nginx configuration
if ($arg_go-get = "1") {
# This is a go-get operation.
return 200 '
<html><head>
<meta name="go-import"
content="k8s.io/$repo
git https://github.com/kubernetes/$repo">
<meta name="go-source"
https://github.com/kubernetes/$repo/tree/master{/dir}
https://github.com/kubernetes/$repo/blob/master{/dir}/{file}#L{line}">
</head></html>
when go get k8s.io/client-go?go-get=1
, return this piece of html code
You’ll use the respond
subdirective with a query
matcher
@goget query go-get=1
respond @goget `your html` 200
You can use backticks or double quotes for strings, backticks work better for wrapping HTML content.
dfang
(fang duan)
3
@francislavoie thanks, i can implement this task with a new template, but your solution is neat,
in your snippet, how to evaluate the $repo variable in backticks quoted html.
the request path matcher regex can refer this
You can use the path_regexp
matcher then use a placeholder to use the match groups in your content. The docs should be self-explanatory.
dfang
(fang duan)
5
a.com {
log
@repo path_regexp ^/(?<repo>[^/]*)(?<subpath>/.*)?$
respond @goget `
<html><head>
content="k8s.io/@repo
git https://github.com/kubernetes/@repo">
https://github.com/kubernetes/@repo/tree/master{/dir}
https://github.com/kubernetes/@repo/blob/master{/dir}/{file}#L{line}">
</head></html>` 200
tried @repo and {{ @repo }} in backticks, not replaced
Please read these sections of the docs:
dfang
(fang duan)
7
my problem is not how to match but how to pass it to backticks
tried this, but it didn’t work as expected
@repo path_regexp repo ^/(?<repo>[^/]*)(?<subpath>/.*)?$
respond @goget `
<html><head>
content="k8s.io/{http.regexp.repo.1}
https://github.com/kubernetes/{http.regexp.repo.1}
https://github.com/kubernetes/{http.regexp.repo.1}/tree/master{/dir}
https://github.com/kubernetes/{http.regexp.repo.1}/blob/master{/dir}/{file}#L{line}">
</head></html>` 200
Please re-read the documentation on named matchers. You’re not using them correctly.
@goget {
query go-get=1
respond @goget `... {http.regexp.repo.1} ...` 200
dfang
(fang duan)
9
it seems caddy doesn’t support lookback and Perl syntax regex
Oct 26 11:15:29 ip-172-31-58-46 caddy[8046]: run: loading initial config: loading new config: loading http app module: provision http: server srv0: setting up route handlers: route 2: loading handler modules: position 0: loading module 'subroute': provision http.handlers.subroute: setting up subroutes: route 0: loading matcher modules: module name 'path_regexp': provision http.matchers.path_regexp: compiling matcher regexp (?<repo>[^\/]*)(\?go-get=1)$: error parsing regexp: invalid or unsupported Perl syntax: `(?<`
i changed to go flavor, it worked.
thanks !
dfang
(fang duan)
10
i post my answer here, for anyone came here
if you write kubernetes operator and want to use custom domain on caddy. you can use this caddy config.
replace a.com
and <user>
respectively
a.com {
log
@goget {
path_regexp repo \/(.*)
query go-get=1
respond @goget `<html><head>
content="jdwl.in/{http.regexp.repo.1}
git https://github.com/<user>/{http.regexp.repo.1}">
https://github.com/<user>/{http.regexp.repo.1}/tree/master{/dir}
https://github.com/<user>/{http.regexp.repo.1}/blob/master{/dir}/{file}#L{line}">
</head></html>` 200
respond * "ok" 200
note:
if you use both query
and path_regexp
, don’t match ?go-get=1
in path_regexp
system
(system)
Closed
11
