Is there a way to enable experimental http3 or any other beginning option just using a cmd command line instead of using a caddyfile?
Hey @Dill,
Sorry to say I don’t believe it is.
Having a quick look over the command list, you can see there is no reference to http3:
Command Line — Caddy Documentation
You can also run caddy help
to get CLI usage info from the binary itself. Suffice to say right now you’ll probably need some conf for this one.
Thank you! I appreciate the response!
