Is it already possible to configure the acme embedded ca via normal caddyfile (not json)
the examples of the PR are very complex, i have searched the forum also.
I have an existing CA and want to migrate from boulder to caddy embedded stepca. I cannot find any example of a simple Caddyfile using the stepca pki.
Caddy should just use the given intermediate CA pem/key ( i dont have the private key of the root ca) to sign acme clients.
I have something like that but it doesnt work:
pki {
ca testca {
name "myca"
root_cn "myca"
intermediate_cn "myca"
root {
format "pem_file"
cert /root/ica.pem
key /root/ica.key
root * /usr/share/caddy
# php_fastcgi localhost:9000
acme_server * {
ca testca
