caddy env file
# Caddy
DOMAIN_NAME=balajidigitals.in
caddyfile in production
{$DOMAIN_NAME} {
redir https://balajidigitals.in
{$DOMAIN_NAME} {
proxy / django:5000 {
header_upstream Host {host}
log stdout
errors stdout
gzip
error when I run docker-compose up
caddy_1 | 2018/04/25 23:48:21 duplicate site address: balajidigitals.in
If you’ll entertain the idea of following the variable substitution, you get…
balajidigitals.in {
balajidigitals.in {
As you can see, this indeed a duplicated site definition.
You can remove the first entry entirely - when port and scheme are unspecified, Caddy serves on both HTTP and HTTPS, and handles the upgrade redirection for you.
I tried removing
{$DOMAIN_NAME} {
getting same error, but when I remove
it will run but my domain will not be reachable.
I tried with domains whose dns is not resolvable thinking that my dns settings on digitalsocean is issue. but it’s something to do with the caddy config.
Thanks for replying on my question
