axora
(Zaq M'Ko)
#1
Hi,
we are thinking to switch from another webserver to caddy. One of our application
uses shibboleth auth.
I tried different search engines, and so far it seems shibboleth is not possible with caddy.
Does caddy support shibboleth auth ?
Are there some auth plugin that would allow shibboleth ?
thank you.
Hi @axora,
I’m afraid that FastCGI is your best bet to get it working, but Caddy doesn’t implement Authorizer mode, so that’s a non-starter right now.
You’re not the only one wanting to use Shibboleth with Caddy, there’s an open feature request at the Github page:
https://github.com/mholt/caddy/issues/1827
axora
(Zaq M'Ko)
#3
Thank you @whitestrake for these precisions.
The clear answer is : caddy does not currently support shibboleth.
Your link was really helpful, and I know now that there is hope. When/if caddy supports fast-cgi authorizers, it will be possible to use shibboleth.
Thanks again.
Zaq.
system
(system)
closed
#4
