1. Output of caddy version
I am using the latest version of the caddy Docker image:
$ docker pull caddy
Using default tag: latest
latest: Pulling from library/caddy
Digest: sha256:50743fc6130295e9e8feccd8b2f437d8c472f626bf277dc873734ed98219f44f
Status: Image is up to date for caddy:latest
docker.io/library/caddy:latest
I am using Docker on Ubuntu 22.04.1.
docker compose up imgsel-caddy
imgsel-api:
container_name: imgsel-api
image: imgsel-api
- imgsel-net
expose:
- 8080:8080
- /home/gamer/kwikserv/imgsel-data/data:/data
# this volume definition has been left out for brevity, it works as expected
- nas_sftp:/media
DATA_FOLDER: "/data"
MASTER_KEY: "<REDACTED>"
MEDIA_DIR: "/media"
tty: true
stdin_open: true
imgsel-client:
container_name: imgsel-client
image: imgsel-client
- imgsel-net
expose:
- 8090:8090
imgsel-caddy:
container_name: imgsel-caddy
image: caddy
depends_on:
- imgsel-api
- imgsel-client
- imgsel-net
- imgsel-web
- 443:443
- 443:443/udp
- /home/gamer/kwikserv/caddy/Caddyfile:/etc/caddy/Caddyfile
- /home/gamer/kwikserv/caddy/data:/data
imgsel-net:
driver: bridge
external: false
imgsel-web:
driver: bridge
external: true
:443 {
level DEBUG
reverse_proxy /api/v1/* imgsel-api:8080
reverse_proxy imgsel-client:8090
I am trying to proxy a client and api through caddy. Both are written by me, and I know it’s not a problem with my programs. The problem is that caddy seems to be unable to connect to other containers. If I change the compose file to use network_mode: host
and update the reverse_proxy
line to use localhost
(and change the expose
fields to ports
), caddy works exactly as expected. I have tried everything I can think of and I am certain the problem is a networking problem.
The problem presents itself as a cryptic error in curl:
$ curl https://localhost -v
* Trying 127.0.0.1:443...
* Connected to localhost (127.0.0.1) port 443 (#0)
* ALPN, offering h2
* ALPN, offering http/1.1
* CApath: /etc/ssl/certs
* TLSv1.2 (IN), TLS header, Unknown (21):
* error:0A000438:SSL routines::tlsv1 alert internal error
* Closing connection 0
curl: (35) error:0A000438:SSL routines::tlsv1 alert internal error
Caddy does not print any errors when this happens. The logs are completely silent as I try this:
$ docker compose up imgsel-caddy
[+] Running 3/0
⠿ Container imgsel-client Created 0.0s
⠿ Container imgsel-api Created 0.0s
⠿ Container imgsel-caddy Created 0.0s
Attaching to imgsel-caddy
imgsel-caddy | {"level":"info","ts":1670138293.420376,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":"caddyfile"}
imgsel-caddy | {"level":"warn","ts":1670138293.4213204,"msg":"Caddyfile input is not formatted; run the 'caddy fmt' command to fix inconsistencies","adapter":"caddyfile","file":"/etc/caddy/Caddyfile","line":9}
imgsel-caddy | {"level":"info","ts":1670138293.421894,"logger":"admin","msg":"admin endpoint started","address":"localhost:2019","enforce_origin":false,"origins":["//localhost:2019","//[::1]:2019","//127.0.0.1:2019"]}
imgsel-caddy | {"level":"info","ts":1670138293.422104,"logger":"http","msg":"server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS","server_name":"srv0","https_port":443}
imgsel-caddy | {"level":"info","ts":1670138293.4221163,"logger":"http","msg":"enabling automatic HTTP->HTTPS redirects","server_name":"srv0"}
imgsel-caddy | {"level":"info","ts":1670138293.4221861,"logger":"tls.cache.maintenance","msg":"started background certificate maintenance","cache":"0xc000412770"}
imgsel-caddy | {"level":"info","ts":1670138293.422477,"logger":"http","msg":"enabling HTTP/3 listener","addr":":443"}
imgsel-caddy | {"level":"info","ts":1670138293.4226046,"logger":"tls","msg":"cleaning storage unit","description":"FileStorage:/data/caddy"}
imgsel-caddy | {"level":"info","ts":1670138293.4226315,"msg":"failed to sufficiently increase receive buffer size (was: 208 kiB, wanted: 2048 kiB, got: 416 kiB). See https://github.com/lucas-clemente/quic-go/wiki/UDP-Receive-Buffer-Size for details."}
imgsel-caddy | {"level":"info","ts":1670138293.4227667,"logger":"http.log","msg":"server running","name":"srv0","protocols":["h1","h2","h3"]}
imgsel-caddy | {"level":"info","ts":1670138293.4227867,"logger":"http.log","msg":"server running","name":"remaining_auto_https_redirects","protocols":["h1","h2","h3"]}
imgsel-caddy | {"level":"info","ts":1670138293.422935,"msg":"autosaved config (load with --resume flag)","file":"/config/caddy/autosave.json"}
imgsel-caddy | {"level":"info","ts":1670138293.42294,"msg":"serving initial configuration"}
imgsel-caddy | {"level":"info","ts":1670138293.4231048,"logger":"tls","msg":"finished cleaning storage units"
I have tried using various hostnames to connect to the containers, as well as many different network setups. I even created a test container as such (attached to the same network as described above):
imgsel-test:
image: debian
- imgsel-net
command: /bin/bash
and when I run it:
$ docker compose run imgsel-test
root@cfa9bed4a2d0:/# apt update >/dev/null 2>/dev/null && apt install curl -y >/dev/null 2>/dev/null
root@cfa9bed4a2d0:/# curl imgsel-client:8090 -v
* Trying 172.22.0.2:8090...
* Connected to imgsel-client (172.22.0.2) port 8090 (#0)
> GET / HTTP/1.1
> Host: imgsel-client:8090
> User-Agent: curl/7.74.0
< HTTP/1.1 200 OK
< Vary: RSC, Next-Router-State-Tree, Next-Router-Prefetch, Accept-Encoding
< X-Powered-By: Next.js
< Content-Type: text/html; charset=utf-8
< Cache-Control: private, no-cache, no-store, max-age=0, must-revalidate
< Date: Sun, 04 Dec 2022 07:24:12 GMT
< Connection: keep-alive
< Keep-Alive: timeout=5
< Transfer-Encoding: chunked
<!DOCTYPE html><html lang="en"> [ truncated for brevity, it sends what it's supposed to ]
This clearly demonstrates my network setup is correct, but Caddy still does not properly serve the HTML content. I am unable to debug the error any further because I cannot see the cause of the curl error, and googling it turned up nothing.
I have thoroughly read through the following documentation and am certain I am using the networks correctly:
