Do wildcard address blocks apply configuration options?
Note: I’m ignoring the template, because it’s geared towards problems and I have more of a general question.
I am trying to figure out how to pare down redundant config declarations. I am wondering if that can be done by using wildcard addresses. However, the only mention of wildcards in the docs is for TLS. So, I am looking for confirmation whether this (below) is or is not possible.
Question: Given the configuration below, will the address ‘sub.example.com’ have logging and compression?
snippets.conf
(logs) {
        output file /var/log/caddy/example
(compress) {
    encode zstd
example.conf
*.example.com {
    import logs
    import compress
sub.example.conf
sub.example.com {
   respond 'hi'
Caddyfile
import snippets.conf
import example.conf
import sub.example.conf
In your example, sub.example.com will NOT inherit configuration from *.example.com.
If you want to reuse code between blocks you’ll need to import the snippets into each block.
An alternative would be to simply not define a separate sub.example.com and instead put it under your *.example.com block with a host matcher:
*.example.com {
  # These execute for all requests
  import logs
  import compress
  @foo host foo.example.com
  handle @foo {
    # Only executes for foo.example.com
    respond "I'm foo"
  @bar host bar.example.com
  handle @bar {
    # Only executes for bar.example.com
    respond "I'm bar"
    # Only executes if none of the others did
    # (handle blocks are mutually exclusive)
    respond "I'm the default handler"
I figured as much, but wanted to check.
Thanks for the confirmation, @Whitestrake.
