1. Output of caddy version
Debian Sid, Caddy installed from official repo
# caddy.service
# for your installation.
Type=notify
User=www-data
Group=www-data
PrivateDevices=yes
storage file_system /var/www/caddy
on_demand_tls {
interval 2m
burst 5
https:// {
on_demand
root * /var/www/{host}/htdocs/
php_fastcgi unix//run/php/php8.2-fpm.sock
php_fastcgi /wp-admin/* unix//run/php/php-admin.sock
file_server {
precompressed br
header /* {
-Server
@cache {
not header_regexp Cookie "comment_author|wordpress_[a-f0-9]+|wp-postpass|wordpress_logged_in"
not path_regexp "(/wp-admin/|/xmlrpc.php|/wp-(app|cron|login|register|mail).php|wp-.*.php|/feed/|index.php|wp-comments-popup.php|wp-links-opml.php|wp-locations.php|sitemap(index)?.xml|[a-z0-9-]+-sitemap([0-9]+)?.xml)"
not method POST
not expression {query} != ''
route @cache {
try_files /wp-content/cache/cache-enabler/{host}{uri}/https-index.html /wp-content/cache/cache-enabler/{host}{uri}/index.html {path} {path}/index.php?{query}
@disallowed {
path /xmlrpc.php
path /wp/xmlrpc.php
path *.sql
path /wp-content/uploads/*.php
rewrite @disallowed '/index.php'
I am trying to use two php-fpm pools for my sites. One for the front-end and another for Wordpress Admin Area. I have added two fastcgi config in the Caddyfile to achieve the same. But it’s not working. The default pool values are still being used all across. I am trying to achieve what this article did but for the whole wp-admin area and not just for update url. Selective Elevation of PHP in Nginx+WordPress » KBeezie
I am not sure if my config is right for php_fastcgi for the admin area. I’ll appreciate some help. Thank you for the amazing work the whole team is doing on Caddy!
