https://caddyserver.com/docs/mitm-detection
I was wondering if anyone had some example code for displaying something like the MITM likely on a page.Or if anyone has the variables to use in the caddyfile to perform a redirect that would also be helpful.
matt
(Matt Holt)
August 3, 2017, 6:34pm
2
Well, just like that docs page suggests:
In your Caddyfile, you can use if {mitm} is likely
in redir or rewrite
In an HTML file (when using the templates directive), you can use {{if .IsMITM}} ... {{end}}
to show content if the page is being intercepted
That particular page is rendered by a process other than Caddy (that’s just how the docs pages work, they’re rendered by the devportal, fronted by Caddy), so for now it serves a JSON response using templates: https://github.com/caddyserver/website/blob/master/site/resources/mitm.html
system
(system)
Closed
November 1, 2017, 6:35pm
3
