Is there any way to log for debugging purposes what headers are being returned by Caddy?
I am looking to diagnose an old unresolved problem. I have one site which will not display at all on any Apple device (iOS or MacOS) when sent over https; it’s OK over http, and OK over both in Windows and Android. At present I can’t think of anything to look for other than an unexpected combination of headers that Apple doesn’t like. The site is generated by Grav (a CMS).
Thanks. I subsequently discovered that the developer tools in any browser can show the headers, which enabled me to fix the problem (a header that shouldn’t have been there at all).
I can’t now put the fix in the right thread. The problem turned out to be that for whatever reason Grav was including a “connection: close” header, which is not valid in HTTP/2. Deleting this header in the Caddy configuration for the Grav site has enabled it to be displayed normally on Apple devices. There may be a Grav configuration item that would also fix it, but I haven’t discovered it yet.
If you’d like, write out the reply you would have posted in the previous thread, post it in this one, and I will move it into the locked thread and mark it as the solution.
