Hello!
When I use the header
directive with defer
to set a custom header in conjunction with the handle_errors
directive, the custom header is not sent to client when an error occurs. However, if I remove the defer
keyword, the header is sent correctly. I show the examples below:
With defer
*.{$DOMAINS__001}, {$DOMAINS__001} {
Example "example"
defer
import docker-service example.{$DOMAINS__001} example 80 # Create a reverse proxy to a Docker service that is down to generate a 502 error.
handle_errors {
respond <<JSON
"status_code": {err.status_code},
"status_text": "{err.status_text}",
"message": "😵💫 {err.status_code} - {err.status_text}"
JSON
~ ❯ http --headers https://example.mydomain.dev
HTTP/1.1 502 Bad Gateway
Alt-Svc: h3=":443"; ma=2592000
Content-Length: 99
Content-Type: application/json
Date: Mon, 09 Sep 2024 16:50:20 GMT
Server: Caddy
Without defer
Example "example"
handle_errors {
respond <<JSON
JSON
Content-Length: 99
Date: Mon, 09 Sep 2024 16:51:28 GMT
Example: example
Server: Caddy
Is this the expected behavior or is it a bug? In my opinion the header called Example
should be set and send to client both with and without defer
Thanks in advance!
Using Docker
and Docker Compose
a. Service/unit/compose file:
build:
context: .
dockerfile: Dockerfile
image: example/caddy
hostname: caddy
- TLS__EMAIL=${TLS__EMAIL}
- TLS__CLOUDFLARE_API_TOKEN=${TLS__CLOUDFLARE_API_TOKEN}
- DOMAINS__001=${DOMAINS__001}
- TZ=${GLOBAL__TIMEZONE}
- ./site:/srv
- ${GLOBAL__VOLUME_DIR}/data:/data
- ${GLOBAL__VOLUME_DIR}/config:/config
- ${GLOBAL__VOLUME_DIR}/logs:/logs
- default
- reverse-proxy
- 443:443
- 443:443/udp
default:
reverse-proxy:
external: true
b. My complete Caddy config:
(docker-service) {
@{args[1]} host {args[0]}
handle @{args[1]} {
reverse_proxy {args[1]}:{args[2]}
# Sites
## Configuration for each site proxied by Caddy.
Example "example"
#defer
handle_errors {
respond <<JSON
JSON
