I am trying to install Caddy with the Cloudflare DNS plugin. The process I’ve gone through is:
- Installed standard package first as per steps here.
- Downloaded custom build with following command.
curl -o caddy "https://caddyserver.com/api/download?os=linux&arch=amd64&p=github.com%2Fcaddy-dns%2Fcloudflare&idempotency=98480474495547"
- Followed Package support files for custom builds for Debian/Ubuntu/Raspbian steps outlined here to insert the custom caddy build.
- Couldn’t restart the service with final command from above steps.
- Eventually worked out that granting rwx permissions for caddy group to
/usr/bin/caddy
allowed the service to run.
Sorry I no longer have the exact error but basically permission denied.
Ubuntu Server 2022.04
x64
systemd
Virtualised in Proxmox
As per above linked instructions.
GNU nano 6.2 /lib/systemd/system/caddy.service
# caddy.service
# for your installation.
Type=notify
# domain name.
root * /usr/share/caddy
# php_fastcgi localhost:9000
NA
I’m a noob with Linux and Caddy. While I appear I’ve fixed it, I expect not. Seeking guidance on issues introduced with my workaround.
