): 2.2.1
As a Windows service set up by nssm, with the single parameter “run”. The Caddyfile is in the same directory alongside. The user has all necessary permissions
Windows server 2019
As stated above - a Windows service with the command “caddy run”
# Top Matter
email pwh@cassland.org
# Sites
thrall.cassland.org {
root * ..\cassland.org\html
basicauth /CherwellSingers/* {
cherwell JDJhJDE0JHBoRjNLQUFJTjNoWTMwSC80eVJBZXVFNHg0cnBRZGowNEZBSTJITFh6eURPLlZxbHVDdzA2
basicauth /Nic/* {
NBH JDJhJDE0JHo5WGN5eGZ6SkNiRlEwYmtaZjlMMWVMeE1rVWIwZjNCNGhDdXJvRGRjVWRxQ1I5V3ozcWpH
basicauth /scores2/* {
pauls JDJhJDE0JGZaLjhRbHVhUWpZZTVMZjhINHNKTGVpTFcyVEpMNDRZMWxTWXl2aEVJejYxREJVOXIzTVlD
@browsedirs {
path /Album*
path /images*
path /sounds*
path /Nic*
path /public*scores2
path /scores*
path /Varicam*
path /TascamMod*
file_server @browsedirs browse
uri /images/QCavi.jpg replace .jpg .php
uri /images/FireDog.jpg replace .jpg .php
php_fastcgi localhost:9128 #(php74nts)
output file .\Logs\CLaccess.log
# Error handler added as workaround for basicauth problem
@auth_error {
expression {http.error.status_code}==401
handle_errors {
header @auth_error {
WWW-Authenticate "Basic realm=\"restricted\""
respond @auth_error 401
handle_errors {
@404 {
expression {http.error.status_code} == '404'
rewrite @404 /404.html
# rewrite @404 /New404.html
# file_server
# handle_errors {
# rewrite * /{http.error.status_code}
# reverse_proxy https://http.cat
If I put my 404 page into the URL, it displays fine; if I address a non-existent resource the response is a blank page, with a status code of 0.
Access log:
2a02:8010:f01e:1:ec53:7e73:a978:26f6 - - [12/Nov/2020:14:43:48 +0000] "GET /shgjkhgdfj.dshdahg HTTP/2.0" 0 0
Debug line on stderr:
Checked the handle_errors block for correctness, by comparing with other recent examples in the forum. Tried the http.cat alternative with the same effect.
I recall that I tried the cat version with Caddy v2.0.0 when I first tried setting up Caddy 2 some months ago, and it worked then; so I’m wondering if there’s been some regression in v2.2.1, at least in the Windows build.
URLs as in the caddyfile
Thanks for any hints…
Paul
