[root@webserver caddy]# caddy version
v2.2.0 h1:sMUFqTbVIRlmA8NkFnNt9l7s0e+0gw+7GPIrhty905A=
I run Caddy in a dedicated CentOS 8 LXC container running under current ProxmoxVE. I installed from the RPM repository. I manage it with the included systemd files. Sometimes I do a quick “caddy reload” with the same Caddyfile that systemd uses. Other than that I don’t play with the API and as of yet I ignore the JSON config file that is there somewhere.
[root@webserver caddy]# systemctl start caddy
[root@webserver system]# pwd
/usr/lib/systemd/system
[root@webserver system]# cat caddy.service
# caddy.service
# for your installation.
After=network.target
[root@webserver caddy.service.d]# pwd
/etc/systemd/system/caddy.service.d
[root@webserver caddy.service.d]# cat override.conf
After=remote-fs.target
The override is in there to ensure that caddy is not started until after the RO NFS mount with all the content is mounted. (It appears that caddy isn’t the least bit amused by it showing up after caddy is already running.)
[root@webserver caddy]# cat Caddyfile
# domain name.
#default_sni www.fotw.info
www.fotw.info {
root * /web/www.fotw.info/data
redir / /flags/index.html
redir /index.html /flags/index.html
file_server {
index index.html
X-Frame-Options SAMEORIGIN
X-XSS-Protection 1;mode=block
Strict-Transport-Security max-age=31622400
Referrer-Policy strict-origin-when-cross-origin
Feature-Policy "geolocation 'none'; midi 'none'; microphone 'none'; camera 'none'; speaker 'none'; vibrate 'none'; payment 'none'"
Cache-Control "public, max-age=259200"
output file /var/log/caddy/www.fotw.info.log
download.fotw.info {
root * /web/www.fotw.info/mirrors
file_server browse
output file /var/log/caddy/download.fotw.info.log
fotw.info {
redir https://www.fotw.info{uri} permanent
output file /var/log/caddy/fotw.info.log
cbfa.vexillology.info {
root * /web/cbfa.vexillology.info/data
file_server {
index index.html
output file /var/log/caddy/cbfa.vexillology.info.log
I’m running multiple virtual hosts sharing a single ipv4 address and, mostly, each with its own ipv6 address. I’ve been migrating sites from a venerable apache install one at a time, as every indication is that caddy is going to be less irritating for a bunch of relatively low-volume, completely static websites.
There is one piece of disturbing behavior that I see in the logs which is new since the migration to caddy: A number of bots are sending their usual streams of GETs, but I’m seeing URIs that exist in www.fotw.info show up in the logs for download.fotw.info and cbfa.vexillology.info, which get 404 responses given that they don’t, and never have to the best of my knowledge, existed in the latter two sites. For example:
{"level":"error","ts":1604183986.0887687,"logger":"http.log.access.log3","msg":"handled request","request":{"remote_addr":"114.119.139.198:30866","proto":"HTTP/1.1","method":"GET","host":"cbfa.vexillology.info","uri":"/flags/co-bolci.html","headers":{"User-Agent":["Mozilla/5.0 (Linux; Android 7.0;) AppleWebKit/537.36 (KHTML, like Gecko) Mobile Safari/537.36 (compatible; PetalBot;+https://aspiegel.com/petalbot)"],"Accept-Language":["en,zh;q=0.1"],"Accept-Encoding":["gzip,deflate"],"Accept":["text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8"],"Connection":["Close"]},"tls":{"resumed":false,"version":771,"cipher_suite":49196,"proto":"","proto_mutual":true,"server_name":"cbfa.vexillology.info"}},"common_log":"114.119.139.198 - - [31/Oct/2020:22:39:46 +0000] \"GET /flags/co-bolci.html HTTP/1.1\" 404 0","duration":0.000087677,"size":0,"status":404,"resp_headers":{"Referrer-Policy":["strict-origin-when-cross-origin"],"Strict-Transport-Security":["max-age=31622400"],"X-Content-Type-Options":["nosniff"],"X-Frame-Options":["SAMEORIGIN"],"X-Xss-Protection":["1;mode=block"],"Cache-Control":["public, max-age=259200"],"Server":["Caddy"],"Feature-Policy":["geolocation 'none'; midi 'none'; microphone 'none'; camera 'none'; speaker 'none'; vibrate 'none'; payment 'none'"]}}
shows a URI, /flags/co-bolci.html , which definitely exists in www.fotw.info, but doesn’t in cbfa.vexillology.info.
I see no evidence of this in the logs of the previous apache server, so I don’t think all the bots are re-spidering bad information.
I can’t replicate this from a browser or from monitoring system that sends GETs and validates some text on the page.
This leads me to the following questions:
- Am I botching something in the Caddyfile?
- Are a variety of bots known to do something odd with SNI & Hosts: that I could work around?
- Might this be a bug?
- Suggestions on how to look at the actual request, given that they’re all encrypted on the wire?
Many thanks.
One thing that I was curious about was whether there might be something going wrong with HTTP connections being kept open and then abused in some fashion. However a search across all logs of the remote_addr shows only one request ever received from one of the seen ip/port combinations:
[root@webserver caddy]# grep 114.119.139.198:30866 *log
cbfa.vexillology.info.log:{"level":"error","ts":1604183986.0887687,"logger":"http.log.access.log3","msg":"handled request","request":{"remote_addr":"114.119.139.198:30866","proto":"HTTP/1.1","method":"GET","host":"cbfa.vexillology.info","uri":"/flags/co-bolci.html","headers":{"User-Agent":["Mozilla/5.0 (Linux; Android 7.0;) AppleWebKit/537.36 (KHTML, like Gecko) Mobile Safari/537.36 (compatible; PetalBot;+https://aspiegel.com/petalbot)"],"Accept-Language":["en,zh;q=0.1"],"Accept-Encoding":["gzip,deflate"],"Accept":["text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8"],"Connection":["Close"]},"tls":{"resumed":false,"version":771,"cipher_suite":49196,"proto":"","proto_mutual":true,"server_name":"cbfa.vexillology.info"}},"common_log":"114.119.139.198 - - [31/Oct/2020:22:39:46 +0000] \"GET /flags/co-bolci.html HTTP/1.1\" 404 0","duration":0.000087677,"size":0,"status":404,"resp_headers":{"Referrer-Policy":["strict-origin-when-cross-origin"],"Strict-Transport-Security":["max-age=31622400"],"X-Content-Type-Options":["nosniff"],"X-Frame-Options":["SAMEORIGIN"],"X-Xss-Protection":["1;mode=block"],"Cache-Control":["public, max-age=259200"],"Server":["Caddy"],"Feature-Policy":["geolocation 'none'; midi 'none'; microphone 'none'; camera 'none'; speaker 'none'; vibrate 'none'; payment 'none'"]}}
