Could not get certificate from issuer / too many failed authorizations recently
Using a Docker-compose caddy, i have the error :slight_smile:
could not get certificate from issuer
with
HTTP 429 urn:ietf:params:acme:error:rateLimited - Error creating new order :: too many failed authorizations recently: see https://letsencrypt.org/docs/failed-validation-limit/
Docker-compose logs
caddy              | {"level":"error","ts":1701686952.3805563,"logger":"tls.obtain","msg":"could not get certificate from issuer","identifier":"xx.xxcom","issuer":"acme-v02.api.letsencrypt.org-directory","error":"HTTP 429 urn:ietf:params:acme:error:rateLimited - Error creating new order :: too many failed authorizations recently: see https://letsencrypt.org/docs/failed-validation-limit/"}
v2.7.5
System environment:
Ubuntu 22
Docker-compose
Complete Caddy config:
docker-compose.yalm
    image: caddy:latest
      - caddy_data:/data
      - caddy_config:/config
      - opereplay-net
      - ACME_AGREE=true # Agree to Let's Encrypt Subscriber Agreement
      - CADDY_DOMAIN=xx.xx.com
    restart: on-failure
Caddyfile
 {$CADDY_DOMAIN} {
    reverse_proxy nginx-openreplay:80
This docker come from Openreplay github : GitHub - openreplay/openreplay: OpenReplay is developer-friendly, self-hosted session replay.
I try to install it locally
I’m a beginner with caddy and look like a common mistake thx for your help
You can remove this, it was only relevant for Caddy v1. With v2 simply using Caddy is implicit agreement.
Do you actually have a space in your Caddyfile before your domain, or is that just a copy-paste mistake? Remove the space.
The error is pretty self explanatory. If you tried to issue a cert too many times recently, then they’ll start blocking your IP for a short time.
You didn’t share enough of your logs for us to know what’s going on. A single log doesn’t show the full picture.
What did you do before you got to this point? That’s what matters here.
