Convert v1 to v2 with EFS and on-demand tls
Version 2
Ubuntu 20.04 LTS
Paste command here.
Caddy Common
gzip
tls support@app.com
errors /var/log/caddy/error.log {
  rotate_size 10
  rotate_keep 10
  rotate_compress
log / /var/log/caddy/access.log "{combined} {hostonly} {latency_ms}" {
  rotate_size 10
  rotate_keep 10
  rotate_compress
Caddyfile
app.com api.app.com docs.app.com admin.app.com business.app.com {
  gzip
  root /home/user/app.com/current/public
  rewrite {
    if {path} is /
    to /app-proxy/{uri}
  rewrite {
    to index.html {path} /app-proxy/{uri}
  proxy /app-proxy unix:/home/user/app.com/shared/tmp/sockets/puma.sock {
    without /app-proxy
:443 {
  import Caddycommon
  gzip
    # on-demand
    ask https://api.app.com/path/present.json
  rewrite {
    if {path} is /
    to /app-proxy/{uri}
  rewrite {
    without /app-proxy
I would like help converting a version 1 configuration file to version 2 without loosing functionality.
The basic setup is two servers running Caddy v2, connected with shared certificate storage on AWS efs using on-demand TLS to create domains on the fly.
Any help would be appreciated.
Have you read the upgrade guide?
Yes, but unfortunately I am not super technical. Any help would be appreciated, it is on a system that is legacy.
i have just posted this as an upwork job if anyone is interested. Log In - Upwork
