I’m currently working on configuring Caddy, and I’m encountering an issue. Specifically, I’d like to have both info logs and error logs in the same file, but my current configuration only provides error logs.
Here’s the context:
The logs I’m generating are crucial for CrowdSec, as they play a significant role in blocking malicious actions from anonymous internet users.
Now, when I configure error logs in the global options, I can successfully receive alerts like the example bellow. However, the problem is that this configuration causes me to lose all the INFO logs. But when i use the level INFO, this time i lose the alert from the WAF
The INFO logs are essential to me, especially when I’m investigating potential false positives in the WAF. They give me a detailed view of what’s happening. Additionally, some of CrowdSec’s scenarios rely on HTTP requests, making INFO logs even more valuable.
Could you please help me figure out how to maintain both INFO and ERROR logs in the same file with Caddy? I’d greatly appreciate it.
example of a WAF log
"level":"error",
"ts":1694079529.148377,
"logger":"http.handlers.waf",
"msg":"[client \"192.168.1.1\"] Coraza: Warning. Path Traversal Attack (/../) or (/.../) [file \"/ruleset/coreruleset/rules/REQUEST-930-APPLICATION-ATTACK-LFI.conf\"] [line \"4002\"] [id \"930100\"] [rev \"\"] [msg \"Path Traversal Attack (/../) or (/.../)\"] [data \"Matched Data: /../ found within REQUEST_URI_RAW: /../../../../../../../../../windows/win.ini\"] [severity \"critical\"] [ver \"OWASP_CRS/4.0.0-rc1\"] [maturity \"0\"] [accuracy \"0\"] [tag \"application-multi\"] [tag \"language-multi\"] [tag \"platform-multi\"] [tag \"attack-lfi\"] [tag \"paranoia-level/1\"] [tag \"OWASP_CRS\"] [tag \"capec/1000/255/153/126\"] [hostname \"\"] [uri \"/../../../../../../../../../windows/win.ini\"] [unique_id \"lDvEDZrssWGJPbGs\"]\n"
I use a docker compose file.
Linux srvone4all 5.4.0-1091-raspi #102-Ubuntu SMP PREEMPT Fri Jul 21 15:19:03 UTC 2023 aarch64 aarch64 aarch64 GNU/Linux
NAME="Ubuntu"
VERSION="20.04.6 LTS (Focal Fossa)"
ID=ubuntu
ID_LIKE=debian
PRETTY_NAME="Ubuntu 20.04.6 LTS"
VERSION_ID="20.04"
HOME_URL="https://www.ubuntu.com/"
SUPPORT_URL="https://help.ubuntu.com/"
BUG_REPORT_URL="https://bugs.launchpad.net/ubuntu/"
PRIVACY_POLICY_URL="https://www.ubuntu.com/legal/terms-and-policies/privacy-policy"
VERSION_CODENAME=focal
UBUNTU_CODENAME=focal
# coraza_waf first must be always included in your Caddyfile for Coraza module to work
order coraza_waf first
persist_config off
level ERROR
servers {
timeouts { # sets timeouts for various actions
idle 10s # timeout for idle connections
read_body 10s # timeout for reading request body
read_header 10s # timeout for reading request header
max_header_size 4KB # sets maximum header size for requests
# Default server block that will respond with a "Not found" message for all requests to port 443
:443 {
log
respond "Not found" 404
# Default server block that will respond with a "Not found" message for all requests to port 80
log
# Pour chacune de nos applications nous aurons des règles différentes à appliquer, si l'on souhaite traiter les faux positifs plus tard.
{$DOMAIN}:443 {
log
coraza_waf {
# On charge les paramètres globaux de coraza.
include /ruleset/coraza.conf
# On charge les paramètres CRS specifique à notre site.
include /ruleset/vaultwarden/*.conf
# On charge toutes les règles CRS que le WAF utilisera.
include /ruleset/coreruleset/rules/*.conf
request_body {
max_size 100KB # sets maximum request body size
# Uncomment this if you want to get a cert via ACME (Let's Encrypt or ZeroSSL).
tls {$EMAIL}
# Uncomment to improve security (WARNING: only use if you understand the implications!)
# If you want to use FIDO2 WebAuthn, set X-Frame-Options to "SAMEORIGIN" or the Browser will block those requests
# By default, Caddy set the following good security practice:
# By default, Vaultwarden actually handle a lot Web Header and caching, which is very nice!
# Enable HTTP Strict Transport Security (HSTS)
Strict-Transport-Security "max-age=15768000;"
#Good Practice Security - Ensure X-Content-Type-Options header is configured and enabled
Referrer-Policy "no-referrer"
#Good Practice Security - X-Content-Type-Options header is configured and enabled
# Disallow the site to be rendered within a frame (clickjacking protection)
X-Frame-Options "SAMEORIGIN"
# Prevent search engines from indexing (optional)
X-Robots-Tag "none"
# Server name removing
-Server
@insecureadmin {
not remote_ip 192.168.1.0/24
path /admin*
redir @insecureadmin /
# Proxy everything to Rocket
reverse_proxy vaultwarden:60278 {
# Send the true remote IP to Rocket, so that vaultwarden can put this in the
# log, so that crowdsec can ban the correct IP.
unifi.one4all.icu:443 {
log
reverse_proxy unifi-controller:8443 {
tls
tls_insecure_skip_verify
@insecureaccess {
respond @insecureaccess "Access Forbidden!" 403
unifi.one4all.icu:80 {
log
reverse_proxy unifi-controller:8080
@insecureaccess {
