Hello everybody again!
I’ve built another Caddy log encoder that lets you log depending on conditions.
In fact, I called it if
You can find its implementation at leodido/caddy-conditional-logging.
You can combine it with other Caddy logging encoders (for example the console
or the json
one, or even another custom one I’ve built jsonselect
You can define the conditions with Go-like expressions.
The parsing and the compilation of the expressions happen at unmarshalling and provisioning time. The matching, clearly, happens at encoding time.
But, let’s take a look at examples to better get a sense of it…
Log only the GET
s:
format if "request>method == `GET`" console
Log only requests coming from Gecko browsers:
format if "request>headers>User-Agent>[0] ~~ `Gecko`" json
Log only 4** and 5** (eg., 404, 409, 500…):
format if "status ~~ `^4` || status ~~ `^5`" json
I think these are self-explanatory, isn’t it?
There’s a lot you can do!
The expression language is documented here. It also supports grouping - ie., (...)
- and operators precedence.
Lemme know what y’all think of it!
Bests,
Leo
