Condensing config for multiple hosts that point to the same upstream into 1 block?
I have 2 caddy instances. On the public instance, I have 7-8 hosts that all proxy traffic to the internal caddy instance and they do so with TLS enabled.
Previously, I had N blocks 1 for each host. I am trying to figure out if I can condense them all into 1 block since all the config parameter are the same except for the TLS SNI value which varies across hosts. I tried to configure it but
I am getting TLS related between a client on the public internet and the public caddy instance. Is there any way to do this without repeating the blocks ?
{"level":"debug","ts":1737673663.7874644,"logger":"http.stdlib","msg":"http: TLS handshake error from 98.80.130.239:3599: no server TLS configuration available for ClientHello: &{CipherSuites:[49196 49195 49200 49199 159 163 158 162 49188 49192 49187 49191 107 106 103 64 49198 49202 49197 49201 49190 49194 49189 49193 49162 49172 49161 49171 57 56 51 50 49157 49167 49156 49166 157 156 61 60 53 47 255] ServerName:git.ishanjain.me SupportedCurves:[CurveP256 CurveP384 CurveP521 CurveID(256) CurveID(257) CurveID(258) CurveID(259) CurveID(260)] SupportedPoints:[0] SignatureSchemes:[ECDSAWithP256AndSHA256 ECDSAWithP384AndSHA384 ECDSAWithP521AndSHA512 PSSWithSHA256 PSSWithSHA384 PSSWithSHA512 SignatureScheme(2057) SignatureScheme(2058) SignatureScheme(2059) PKCS1WithSHA256 PKCS1WithSHA384 PKCS1WithSHA512 SignatureScheme(1026) SignatureScheme(771) SignatureScheme(769) SignatureScheme(770) ECDSAWithSHA1 PKCS1WithSHA1 SignatureScheme(514)] SupportedProtos:[] SupportedVersions:[771 770 769] Conn:0xc00148cdd8 config:0xc0015db180 ctx:0xc00041caa0}"}
Built using xcaddy with a few custom modules
OS: Arch linux
Arch: amd64
systemd 256 (256.1-1-arch-g34ba18b^)
caddy run --config /etc/caddy/caddy.json
  "apps": {
    "geoip2": {
      "accountId": 362099,
      "databaseDirectory": "/var/lib/caddy",
      "editionID": "GeoLite2-City",
      "lockFile": "/var/lib/caddy/db.lck",
      "updateFrequency": 86400,
      "updateUrl": "https://updates.maxmind.com"
    "http": {
      "servers": {
        "srv0": {
          "listen": [
            ":443"
          "logs": {
            "logger_names": {
              "auth.ishanjain.me": "log0",
              "cups.home.ishanjain.me": "log0",
              "dash.ishanjain.me": "log0",
              "dl.ishanjain.me": "log0",
              "dns.ishan.pw": "local_only",
              "git.ishanjain.me": "log0",
              "ha.home.ishanjain.me": "log0",
              "home.dns.ishan.pw": "log0",
              "influx.home.ishanjain.me": "log0",
              "irc.ishanjain.me": "log0",
              "jellyfin.ishanjain.me": "log0",
              "ldap.ishanjain.me": "log0",
              "money.ishanjain.me": "log0",
              "omada.home.ishanjain.me": "log0",
              "pdf.ishanjain.me": "log0",
              "public.dns.ishan.pw": "log0",
              "pve.home.ishanjain.me": "log0",
              "pvenas.home.ishanjain.me": "log0",
              "pvepc.home.ishanjain.me": "log0",
              "qbit.ishanjain.me": "log0",
              "rss.ishanjain.me": "log0",
              "status.ishanjain.me": "log0",
              "vault.ishanjain.me": "log0"
          "routes": [
              "handle": [
                  "enable": "trusted_proxies",
                  "handler": "geoip2"
                  "handler": "headers",
                  "request": {
                    "set": {
                      "X-Forwarded-For": [
                        "{http.request.remote.host}"
                      "X-Real-IP": [
                  "response": {
                    "deferred": true,
                    "delete": [
                      "Server"
                    "set": {
                      "X-City": [
                        "{geoip2.city_name}"
                      "X-Continent": [
                        "{geoip2.continent_code}"
                      "X-Country": [
                        "{geoip2.country_code}"
                      "X-Latitude": [
                        "{geoip2.location_latitude}"
                      "X-Longitude": [
                        "{geoip2.location_longitude}"
                      "X-State": [
                        "{geoip2.subdivisions_1_iso_code}"
              "terminal": false
              "group": "adguardhome",
              "handle": [
                  "handler": "subroute",
                  "routes": [
                      "handle": [
                          "handler": "reverse_proxy",
                          "transport": {
                            "protocol": "http",
                            "tls": {
                              "server_name": "dns.ishan.pw"
                          "upstreams": [
                              "dial": "127.0.0.1:8443"
                      "match": [
                          "host": [
                            "dns.ishan.pw"
                          "path": [
                            "/dns-query/*"
                      "handle": [
                          "upstreams": [
                              "dial": "127.0.0.1:1030"
                      "match": [
                          "host": [
                      "handle": [
                          "transport": {
                            "compression": true,
                            "protocol": "http",
                            "tls": {
                          "upstreams": [
                              "dial": "10.0.99.14:443"
                      "match": [
                          "host": [
                            "home.dns.ishan.pw"
              "match": [
                  "host": [
                    "*.ishan.pw",
                    "*.dns.ishan.pw"
              "terminal": true
              "handle": [
                  "encodings": {
                    "gzip": {}
                  "handler": "encode",
                  "prefer": [
                    "gzip"
                  "handler": "file_server",
                  "root": "/home/ishan/dl"
              "match": [
                  "host": [
                    "dl.ishanjain.me"
              "terminal": true
              "handle": [
                  "upstreams": [
                      "dial": "127.0.0.1:1337"
              "match": [
                  "host": [
              "terminal": true
              "handle": [
                  "upstreams": [
                      "dial": "127.0.0.1:4242"
              "match": [
                  "host": [
                    "rss.ishanjain.me"
              "terminal": true
              "handle": [
                  "upstreams": [
                      "dial": "127.0.0.1:3030"
              "match": [
                  "host": [
              "terminal": true
              "handle": [
                  "upstreams": [
                      "dial": "10.0.50.17:9091"
              "match": [
                  "host": [
                    "auth.ishanjain.me"
              "terminal": true
              "group": "homecaddy",
              "handle": [
                  "health_checks": {
                    "active": {
                      "expect_status": 200,
                      "interval": "10s",
                      "port": 9001,
                      "timeout": "10s",
                      "uri": "/"
                  "load_balancing": {
                    "retries": 2,
                    "selection_policy": {
                      "policy": "first"
                    "try_duration": "3s",
                    "try_interval": "10ms"
                  "transport": {
                    "protocol": "http",
                    "tls": {
                      "server_name": "pvenas.home.ishanjain.me"
                  "upstreams": [
                      "dial": "10.0.50.3:443"
              "match": [
                  "host": [
                    "cups.home.ishanjain.me",
                    "dash.ishanjain.me",
                    "git.ishanjain.me",
                    "ha.home.ishanjain.me",
                    "influx.home.ishanjain.me",
                    "irc.ishanjain.me",
                    "jellyfin.ishanjain.me",
                    "ldap.ishanjain.me",
                    "money.ishanjain.me",
                    "omada.home.ishanjain.me",
                    "pdf.ishanjain.me",
                    "qbit.ishanjain.me"
              "terminal": true
              "handle": [
                  "handle_response": [
                      "match": {
                        "status_code": [
                          2
                      "routes": [
                          "handle": [
                              "handler": "vars"
                  "headers": {
                    "request": {
                      "set": {
                        "X-Forwarded-Method": [
                          "{http.request.method}"
                        "X-Forwarded-Uri": [
                          "{http.request.uri}"
                  "rewrite": {
                    "method": "GET",
                    "uri": "/api/authz/forward-auth"
                  "upstreams": [
                  "health_checks": {
                    "active": {
                      "interval": "10s",
                      "port": 8006,
                      "timeout": "10s",
                      "uri": "/"
                  "load_balancing": {
                    "retries": 2,
                      "policy": "first"
                  "transport": {
                    "protocol": "http",
                    "tls": {
                      "server_name": "pvepc.home.ishanjain.me"
                  "upstreams": [
                      "dial": "10.0.99.4:8006"
              "match": [
                  "host": [
              "terminal": true
              "handle": [
                      "match": {
                        "status_code": [
                          2
                      "routes": [
                          "handle": [
                              "handler": "vars"
                  "headers": {
                    "request": {
                      "set": {
                  "rewrite": {
                    "method": "GET",
                  "upstreams": [
                  "health_checks": {
                    "active": {
                      "interval": "10s",
                      "port": 8006,
                      "timeout": "10s",
                      "uri": "/"
                  "load_balancing": {
                    "retries": 2,
                      "policy": "first"
                  "transport": {
                    "protocol": "http",
                    "tls": {
                  "upstreams": [
                      "dial": "10.0.99.9:8006"
              "match": [
                  "host": [
              "terminal": true
              "handle": [
                      "match": {
                        "status_code": [
                          2
                      "routes": [
                          "handle": [
                              "handler": "vars"
                  "headers": {
                    "request": {
                      "set": {
                  "rewrite": {
                    "method": "GET",
                  "upstreams": [
                  "health_checks": {
                    "active": {
                      "interval": "10s",
                      "port": 8006,
                      "timeout": "10s",
                      "uri": "/"
                  "load_balancing": {
                    "retries": 2,
                      "policy": "first"
                  "transport": {
                    "protocol": "http",
                    "tls": {
                      "server_name": "pve.home.ishanjain.me"
                  "upstreams": [
                      "dial": "10.0.99.8:8006"
              "match": [
                  "host": [
              "terminal": true
          "tls_connection_policies": [
              "client_authentication": {
                "mode": "require_and_verify",
                "trusted_ca_certs": [
              "match": {
                "sni": []
              "protocol_min": "tls1.3"
    "tls": {
      "automation": {
        "policies": [
            "issuers": [
                "challenges": {
                  "dns": {
                    "provider": {
                      "name": "cloudflare"
                  "http": {
                    "disabled": false
                  "tls-alpn": {
                    "disabled": false
                "email": "contact@ishanjain.me",
                "module": "acme"
            "subjects": [
              "*.home.ishanjain.me",
              "*.ishanjain.me",
              "*.ishan.pw",
              "*.dns.ishan.pw",
              "dns.ishan.pw"
  "logging": {
    "logs": {
      "discard": {
        "writer": {
          "output": "discard"
      "garbage": {
        "encoder": {
          "format": "json"
        "exclude": [
          "http.log.access.log0",
          "http.log.access.local_only"
        "include": [
          "http.log.access"
        "writer": {
          "filename": "/var/log/caddy/garbage.txt",
          "output": "file",
          "roll_keep_days": 180,
          "roll_local_time": true,
          "roll_size_mb": 400
      "influx_log": {
        "encoder": {
          "format": "json"
        "include": [
        "writer": {
          "bucket": "caddy-del",
          "host": "http://10.0.50.8:8086",
          "ignore_fields": [
            "level",
            "logger",
            "msg",
            "request_headers_Accept-Encoding",
            "resp_headers_Cache-Control",
            "resp_headers_Date",
            "resp_headers_X-Xss-Protection_0",
            "tls",
            "ts"
          "measurement": "access",
          "org": "homelab",
          "output": "influx_log",
          "tags": {
            "request_city": "{resp_headers_X-City_0}",
            "request_continent": "{resp_headers_X-Continent_0}",
            "request_country": "{resp_headers_X-Country_0}",
            "request_host": "{request_host}",
            "request_method": "{request_method}",
            "request_proto": "{request_proto}",
            "request_state": "{resp_headers_X-State_0}",
            "request_status": "{status}",
            "request_user_agent": "{request_headers_User-Agent_0}"
      "local_only": {
        "encoder": {
          "format": "json"
        "include": [
        "writer": {
          "filename": "/var/log/caddy/local_only.txt",
          "output": "file",
          "roll_size_mb": 400
      "local_warn": {
        "encoder": {
          "format": "json"
        "include": [
          "http.handlers.reverse_proxy"
        "level": "warn",
        "writer": {
          "filename": "/var/log/caddy/reverse_proxy_warn.txt",
          "output": "file",
          "roll_size_mb": 400
      "log0": {
        "encoder": {
          "format": "json"
        "include": [
        "writer": {
          "filename": "/var/log/caddy/log.txt",
          "output": "file",
          "roll_size_mb": 400
"debug": {
        "encoder": {
          "format": "json"
	"level": "debug",
        "include": [
        "writer": {
          "filename": "/var/log/caddy/debug.txt",
          "output": "file",
          "roll_size_mb": 400
I have vault.ishanjain.me in the public proxy config which was not touched at all by my latest changes and it’s also inaccessible so I have definitely made an error some where. I am looking at the diffs and don’t see any thing obvious :thinking:
I see Feature Request: support placeholders in tls_server_name · Issue #4079 · caddyserver/caddy · GitHub and Another run at making reverse proxy TLS server name replaceable for SNI upstreams by kresike · Pull Request #4836 · caddyserver/caddy · GitHub
I tried setting "server_name": "{http.request.host}" but I still get 503 from the internal caddy instance
I also tried using the placeholder {http.request.tls.server_name} and I get the same 503 errors from the internal caddy instance.
I think I figured out why. It does active health checks. These fields are not set in those checks so the healthcheck fails and the public proxy returns 503
{"level":"debug","ts":1737676798.1185045,"logger":"events","msg":"event","name":"tls_get_certificate","id":"f0363866-17da-4a0d-85db-e8bc205f006c","origin":"tls","data":{"client_hello":{"CipherSuites":[4867,4866,4865,52393,52392,52394,49200,49196,49192,49188,49172,49162,159,107,57,65413,196,136,129,157,61,53,192,132,49199,49195,49191,49187,49171,49161,158,103,51,190,69,156,60,47,186,65,49169,49159,5,4,49170,49160,22,10,255],"ServerName":"jellyfin.ishanjain.me","SupportedCurves":[29,23,24,25],"SupportedPoints":"AA==","SignatureSchemes":[2054,1537,1539,2053,1281,1283,2052,1025,1027,513,515],"SupportedProtos":["h2","http/1.1"],"SupportedVersions":[772,771,770,769],"RemoteAddr":{"IP":"27.7.96.110","Port":64098,"Zone":""},"LocalAddr":{"IP":"139.84.164.110","Port":443,"Zone":""}}}}
{"level":"debug","ts":1737676798.1186442,"logger":"tls.handshake","msg":"choosing certificate","identifier":"jellyfin.ishanjain.me","num_choices":1}
{"level":"debug","ts":1737676798.1186519,"logger":"tls.handshake","msg":"default certificate selection results","identifier":"jellyfin.ishanjain.me","subjects":["jellyfin.ishanjain.me"],"managed":true,"issuer_key":"acme-v02.api.letsencrypt.org-directory","hash":"bb3346e6a4edc1bbb2c19ce7f1827ed432645ee9c57cbab10c9a202898d3b639"}
{"level":"debug","ts":1737676798.1186588,"logger":"tls.handshake","msg":"matched certificate in cache","remote_ip":"27.7.96.110","remote_port":"64098","subjects":["jellyfin.ishanjain.me"],"managed":true,"expiration":1745447696,"hash":"bb3346e6a4edc1bbb2c19ce7f1827ed432645ee9c57cbab10c9a202898d3b639"}
{"level":"error","ts":1737676798.1882393,"logger":"http.log.error.log0","msg":"no upstreams available","request":{"remote_ip":"27.7.96.110","remote_port":"64098","client_ip":"27.7.96.110","proto":"HTTP/2.0","method":"GET","host":"jellyfin.ishanjain.me","uri":"/web/","headers":{"User-Agent":["curl/8.7.1"],"Accept":["*/*"]},"tls":{"resumed":false,"version":772,"cipher_suite":4867,"proto":"h2","server_name":"jellyfin.ishanjain.me"}},"duration":0.020561042,"status":503,"err_id":"cwkjw493b","err_trace":"reverseproxy.(*Handler).proxyLoopIteration (reverseproxy.go:524)"}
{"level":"error","ts":1737676798.1883893,"logger":"http.log.access.log0","msg":"handled request","request":{"remote_ip":"27.7.96.110","remote_port":"64098","client_ip":"27.7.96.110","proto":"HTTP/2.0","method":"GET","host":"jellyfin.ishanjain.me","uri":"/web/","headers":{"User-Agent":["curl/8.7.1"],"Accept":["*/*"]},"tls":{"resumed":false,"version":772,"cipher_suite":4867,"proto":"h2","server_name":"jellyfin.ishanjain.me"}},"bytes_read":0,"user_id":"","duration":0.020561042,"size":0,"status":503,"resp_headers":{"Server":["Caddy"],"Alt-Svc":["h3=\":443\"; ma=2592000"]}}
{"level":"debug","ts":1737676799.779136,"logger":"tls.handshake","msg":"no matching certificates and no custom selection logic","identifier":"*.ishanjain.me"}
{"level":"debug","ts":1737676799.7791412,"logger":"tls.handshake","msg":"no matching certificates and no custom selection logic","identifier":"*.*.me"}
{"level":"debug","ts":1737676799.7791455,"logger":"tls.handshake","msg":"no matching certificates and no custom selection logic","identifier":"*.*.*"}
{"level":"debug","ts":1737676801.5640883,"logger":"http.handlers.reverse_proxy","msg":"selected upstream","dial":"10.0.50.17:9091","total_upstreams":1}
{"level":"info","ts":1737676801.570513,"logger":"http.handlers.reverse_proxy.health_checker.active","msg":"HTTP request failed","host":"10.0.50.3:9001","error":"Get \"https://10.0.50.3:9001/\": remote error: tls: internal error"}
{"level":"info","ts":1737676801.5730617,"logger":"http.handlers.reverse_proxy.health_checker.active","msg":"HTTP request failed","host":"[2a0a:6040:4004:50::cad]:9001","error":"Get \"https://[2a0a:6040:4004:50::cad]:9001/\": remote error: tls: internal error"}
Yep! Active healthchecks and placeholders in TLS SNI field do not work well together.
Healthchecks can be done on a different port but it uses the same scheme as the configured upstreams.
TL;DR is, It looks like my plan to condense config will not work if I want a clean solution.
I could make it work if I had a wild card tls certificate that could be used for all 7-8 hosts and then use that in the server_name field but 2 things there.
  1. server_name does not work with wildcard so I can’t do *.ishanjain.me.
  2. Setting SNI to 1 of the 7-8 hosts in the server_name field works because caddy matches requests by the Host header in request not by SNI but this feels ugly to me so I don’t know if I am going to do it
Lastly, The other problem where all configured blocks were returning tls errors with the config I shared in my first message. I don’t know the root cause for it yet. I reverted back to the last revision then instead of condensing everything, condensed just 1 block and then made some progress figuring this out.
I must be making some silly error, don’t see any other reason why it would break so badly
My other problem where all configured hosts were returning tls errors was happening because I erased an empty block from tls_connection_policies.
This works
                "trusted_ca_certs": []
              "match": {
                "sni": []
This throws tls errors
              "match": {
                "sni": []
