in the earlier versions of caddy the readme lined out that you can run build.go with the -goos and -goarch to compile for other platforms.
with the v1 release the entire process changed with the build.go apparently no longer being involved. so how does one now compile for other platforms? or has that sadly become impossible and one needs to install go on any target platform one may want?
okay, I was just confused because the instructions were gone.
although personally I think it was slightly easier hitting the compile for multiple platforms with the 2 as parameters, rather than having to poke around in the control panel for the environment variables.
