Combining two filter
I have some services which I proxy using caddy. Some of these services should only be accessible from within my network, some should be exposed to the internet. I have set up a working localSubnets filter for the first one:
(localSubnets) {
	@localSubnets remote_ip private_ranges
Now I want to harden the security for the exposed services by implementing geoblocking and only allowing traffic from Germany. I was able to create a filter for that using the maxmind module:
(DEgeofilter) {
	@DEgeofilter {
		maxmind_geolocation {
			db_path "/etc/caddy/GeoLite2-Country.mmdb"
			allow_countries DE
However, this denies access from within my local network, probably because these IPs are not “German” IPs. Because of that, I currently use this redundant setup:
test.example.de {
	import DEgeofilter
	import localSubnets
	handle @DEgeofilter {
		reverse_proxy http://192.168.188.70:8787
	handle @localSubnets {
	respond 403
Now my question: How can I combine these two into one filter?
I would like to have something like this (which sadly does not work):
(combinedFilter) {
	@combinedFilter {
                OR
			allow_countries DE
test.example.com {
	import combinedFilter
	handle @combinedFilter {
	respond 403
NA
/srv # caddy version
Docker compose on debian 12
NA
Dockerfile:
FROM caddy:2.7.6-builder AS builder
RUN xcaddy build --with github.com/porech/caddy-maxmind-geolocation
FROM caddy:2.7.6
Docker compose file:
version: "3.7"
    build: .
    cap_add:
      - NET_ADMIN
      - "443:443/udp"
      - ./site:/srv
      - ./data:/data
      - ./config:/config
      - ./GeoLite2-Country.mmdb:/etc/caddy/GeoLite2-Country.mmdb
See above
NA
When putting two matchers inside of a named matcher, matchers of a different type are ANDed together. There’s no way to OR them together traditionally.
It is possible to OR them abusing De Morgan’s Laws with the not matcher, but this is super not nice to use.
We have the expression matcher which can allow you to write more complex boolean expressions, but the problem is you’re using a matcher plugin, and I don’t think that plugin implements the interfaces necessary to allow it to work within CEL expressions. If it did though, it would be possible to write something like this:
@isDEorLocal `remote_ip('192.168.0.0/16','172.16.0.0/12','10.0.0.0/8','127.0.0.1/8','fd00::/8','::1') || maxmind_geolocation({'db_path': '/etc/caddy/GeoLite2-Country.mmdb', 'allow_countries': ['DE'])`
All that said, I think the approach using two handle is correct. The first matching handle block will handle the request. If it doesn’t match, it just falls through to the next one.
Are you sure it’s not working correctly? How are you testing? What IP address does the request have when it “does the wrong thing”?
Thanks for the reply.
It’s not that my current config isn’t working, I just thought there would be a nicer and / or simpler way of doing it. But I’ll just keep using the two handle then.
