v2.4.0-beta.1 h1:Ed/tIaN3p6z8M3pEiXWJL/T8JmCqV62FrSJCHKquW/I=
OS: Raspbian GNU/Linux 10 (buster)
Caddy running inside a docker container.
Dockerfile:
FROM caddy:2.3.0-builder AS builder
RUN xcaddy build \
FROM caddy:2.3.0
Docker Compose file:
version: "3"
# The name and tag I provided my built image.
image: caddy:cloudflare
- 443:443
- ./caddy_data:/data
# Mount Caddyfile
CLOUDFLARE_API_TOKEN: "API token here."
ACME_EMAIL: "Email here."
admin off
email {env.ACME_EMAIL}
# Wildcard: https://github.com/caddyserver/caddy/issues/3200#issuecomment-638608401
*.net.dbren.uk, net.dbren.uk {
@sub {
host app.net.dbren.uk
handle @sub {
reverse_proxy localhost:1080
I’m trying to use Caddy in a docker container to obtain a certificate for a wildcard subdomain (ie. *.net.dbren.uk) using the DNS-01 challenge type.
The domain is managed using Cloudflare.
Running the command caddy list modules
inside the container shows that the module Cloudflare module is installed:
dns.providers.cloudflare
Non-standard modules: 1
I’m providing my email address and Cloudflare API token using environment variables. Furthermore, I’m trying to get this working using the Let’s Encrypt staging environment before using the production endpoint.
I have checked and I’m definitely using a Cloudflare API token as instructed here with the permissions:
Zone / Zone / Read
Zone / DNS / Edit
With Zone Resources set to include the specific zone for my domain.
{"level":"info","ts":1615117765.0986633,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":"caddyfile"}
[WARNING][caddyfile] /etc/caddy/Caddyfile:1: input is not formatted with 'caddy fmt'
{"level":"warn","ts":1615117765.1082976,"logger":"admin","msg":"admin endpoint disabled"}
{"level":"info","ts":1615117765.109268,"logger":"tls.cache.maintenance","msg":"started background certificate maintenance","cache":"0x309aa00"}
{"level":"info","ts":1615117765.1100245,"logger":"http","msg":"server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS","server_name":"srv0","https_port":443}
{"level":"info","ts":1615117765.1101475,"logger":"http","msg":"enabling automatic HTTP->HTTPS redirects","server_name":"srv0"}
{"level":"info","ts":1615117765.1119108,"logger":"tls","msg":"cleaned up storage units"}
{"level":"debug","ts":1615117765.1127994,"logger":"http","msg":"starting server loop","address":"[::]:443","http3":false,"tls":true}
{"level":"debug","ts":1615117765.113149,"logger":"http","msg":"starting server loop","address":"[::]:80","http3":false,"tls":false}
{"level":"info","ts":1615117765.1132264,"logger":"http","msg":"enabling automatic TLS certificate management","domains":["*.net.dbren.uk","net.dbren.uk"]}
{"level":"info","ts":1615117765.1167908,"logger":"tls.obtain","msg":"acquiring lock","identifier":"net.dbren.uk"}
{"level":"info","ts":1615117765.1167905,"logger":"tls.obtain","msg":"acquiring lock","identifier":"*.net.dbren.uk"}
{"level":"info","ts":1615117765.118571,"msg":"autosaved config","file":"/config/caddy/autosave.json"}
{"level":"info","ts":1615117765.1186473,"msg":"serving initial configuration"}
{"level":"info","ts":1615117765.191888,"logger":"tls.obtain","msg":"lock acquired","identifier":"net.dbren.uk"}
{"level":"info","ts":1615117765.2382996,"logger":"tls.obtain","msg":"lock acquired","identifier":"*.net.dbren.uk"}
{"level":"debug","ts":1615117766.057885,"logger":"tls.issuance.acme.acme_client","msg":"http request","method":"GET","url":"https://acme-staging-v02.api.letsencrypt.org/directory","headers":{"User-Agent":["Caddy/2.4.0-beta.1 CertMagic acmez (linux; arm)"]},"status_code":200,"response_headers":{"Cache-Control":["public, max-age=0, no-cache"],"Content-Length":["724"],"Content-Type":["application/json"],"Date":["Sun, 07 Mar 2021 11:49:25 GMT"],"Server":["nginx"],"Strict-Transport-Security":["max-age=604800"],"X-Frame-Options":["DENY"]}}
{"level":"debug","ts":1615117766.2023299,"logger":"tls.issuance.acme.acme_client","msg":"http request","method":"HEAD","url":"https://acme-staging-v02.api.letsencrypt.org/acme/new-nonce","headers":{"User-Agent":["Caddy/2.4.0-beta.1 CertMagic acmez (linux; arm)"]},"status_code":200,"response_headers":{"Cache-Control":["public, max-age=0, no-cache"],"Date":["Sun, 07 Mar 2021 11:49:26 GMT"],"Link":["<https://acme-staging-v02.api.letsencrypt.org/directory>;rel=\"index\""],"Replay-Nonce":["0004vib9oEd8eH22ooo-LcmjLgZrXFmpz55_ilrHp3vT8yQ"],"Server":["nginx"],"Strict-Transport-Security":["max-age=604800"],"X-Frame-Options":["DENY"]}}
{"level":"debug","ts":1615117766.354741,"logger":"tls.issuance.acme.acme_client","msg":"http request","method":"POST","url":"https://acme-staging-v02.api.letsencrypt.org/acme/new-acct","headers":{"Content-Type":["application/jose+json"],"User-Agent":["Caddy/2.4.0-beta.1 CertMagic acmez (linux; arm)"]},"status_code":201,"response_headers":{"Boulder-Requester":["18439568"],"Cache-Control":["public, max-age=0, no-cache"],"Content-Length":["323"],"Content-Type":["application/json"],"Date":["Sun, 07 Mar 2021 11:49:26 GMT"],"Link":["<https://acme-staging-v02.api.letsencrypt.org/directory>;rel=\"index\"","<https://letsencrypt.org/documents/LE-SA-v1.2-November-15-2017.pdf>;rel=\"terms-of-service\""],"Location":["https://acme-staging-v02.api.letsencrypt.org/acme/acct/18439568"],"Replay-Nonce":["0003cHX9YWsLpgzaSSn1mdDlh39qA5xPC9CLTeuW7X1VzlY"],"Server":["nginx"],"Strict-Transport-Security":["max-age=604800"],"X-Frame-Options":["DENY"]}}
{"level":"debug","ts":1615117766.657894,"logger":"tls.issuance.acme.acme_client","msg":"http request","method":"HEAD","url":"https://acme-staging-v02.api.letsencrypt.org/acme/new-nonce","headers":{"User-Agent":["Caddy/2.4.0-beta.1 CertMagic acmez (linux; arm)"]},"status_code":200,"response_headers":{"Cache-Control":["public, max-age=0, no-cache"],"Date":["Sun, 07 Mar 2021 11:49:26 GMT"],"Link":["<https://acme-staging-v02.api.letsencrypt.org/directory>;rel=\"index\""],"Replay-Nonce":["0004gxDEPIixfxjFMm7Yasf2sHvuK9iubYaJ78JYy2Mbz-A"],"Server":["nginx"],"Strict-Transport-Security":["max-age=604800"],"X-Frame-Options":["DENY"]}}
{"level":"debug","ts":1615117766.811533,"logger":"tls.issuance.acme.acme_client","msg":"http request","method":"POST","url":"https://acme-staging-v02.api.letsencrypt.org/acme/new-acct","headers":{"Content-Type":["application/jose+json"],"User-Agent":["Caddy/2.4.0-beta.1 CertMagic acmez (linux; arm)"]},"status_code":201,"response_headers":{"Boulder-Requester":["18439569"],"Cache-Control":["public, max-age=0, no-cache"],"Content-Length":["323"],"Content-Type":["application/json"],"Date":["Sun, 07 Mar 2021 11:49:26 GMT"],"Link":["<https://acme-staging-v02.api.letsencrypt.org/directory>;rel=\"index\"","<https://letsencrypt.org/documents/LE-SA-v1.2-November-15-2017.pdf>;rel=\"terms-of-service\""],"Location":["https://acme-staging-v02.api.letsencrypt.org/acme/acct/18439569"],"Replay-Nonce":["00040plzHUe-6x4C_ocoCoQ3-HYOqUNhHu-kjFvY9T5nl_Y"],"Server":["nginx"],"Strict-Transport-Security":["max-age=604800"],"X-Frame-Options":["DENY"]}}
{"level":"info","ts":1615117766.8466969,"logger":"tls.issuance.acme","msg":"waiting on internal rate limiter","identifiers":["net.dbren.uk"]}
{"level":"info","ts":1615117766.8469384,"logger":"tls.issuance.acme","msg":"done waiting on internal rate limiter","identifiers":["net.dbren.uk"]}
{"level":"debug","ts":1615117767.024617,"logger":"tls.issuance.acme.acme_client","msg":"http request","method":"POST","url":"https://acme-staging-v02.api.letsencrypt.org/acme/new-order","headers":{"Content-Type":["application/jose+json"],"User-Agent":["Caddy/2.4.0-beta.1 CertMagic acmez (linux; arm)"]},"status_code":201,"response_headers":{"Boulder-Requester":["18439568"],"Cache-Control":["public, max-age=0, no-cache"],"Content-Length":["342"],"Content-Type":["application/json"],"Date":["Sun, 07 Mar 2021 11:49:26 GMT"],"Link":["<https://acme-staging-v02.api.letsencrypt.org/directory>;rel=\"index\""],"Location":["https://acme-staging-v02.api.letsencrypt.org/acme/order/18439568/3847307"],"Replay-Nonce":["0004Xu0Mcm3nA9R6HxKLj3vY5ZDJfRidXldNcMyj9YKE4s0"],"Server":["nginx"],"Strict-Transport-Security":["max-age=604800"],"X-Frame-Options":["DENY"]}}
{"level":"debug","ts":1615117767.173732,"logger":"tls.issuance.acme.acme_client","msg":"http request","method":"POST","url":"https://acme-staging-v02.api.letsencrypt.org/acme/authz-v3/3192508","headers":{"Content-Type":["application/jose+json"],"User-Agent":["Caddy/2.4.0-beta.1 CertMagic acmez (linux; arm)"]},"status_code":200,"response_headers":{"Boulder-Requester":["18439568"],"Cache-Control":["public, max-age=0, no-cache"],"Content-Length":["805"],"Content-Type":["application/json"],"Date":["Sun, 07 Mar 2021 11:49:27 GMT"],"Link":["<https://acme-staging-v02.api.letsencrypt.org/directory>;rel=\"index\""],"Replay-Nonce":["00044oHEQHwYrwvZO7V1fu7zXjVjizdN5eONeM4AuwYH1MI"],"Server":["nginx"],"Strict-Transport-Security":["max-age=604800"],"X-Frame-Options":["DENY"]}}
{"level":"debug","ts":1615117767.1755733,"logger":"tls.issuance.acme.acme_client","msg":"no solver configured","challenge_type":"tls-alpn-01"}
{"level":"debug","ts":1615117767.1756752,"logger":"tls.issuance.acme.acme_client","msg":"no solver configured","challenge_type":"http-01"}
{"level":"info","ts":1615117767.1757185,"logger":"tls.issuance.acme.acme_client","msg":"trying to solve challenge","identifier":"net.dbren.uk","challenge_type":"dns-01","ca":"https://acme-staging-v02.api.letsencrypt.org/directory"}
{"level":"info","ts":1615117767.43741,"logger":"tls.issuance.acme","msg":"waiting on internal rate limiter","identifiers":["*.net.dbren.uk"]}
{"level":"info","ts":1615117767.4375975,"logger":"tls.issuance.acme","msg":"done waiting on internal rate limiter","identifiers":["*.net.dbren.uk"]}
{"level":"debug","ts":1615117767.5982428,"logger":"tls.issuance.acme.acme_client","msg":"http request","method":"POST","url":"https://acme-staging-v02.api.letsencrypt.org/acme/new-order","headers":{"Content-Type":["application/jose+json"],"User-Agent":["Caddy/2.4.0-beta.1 CertMagic acmez (linux; arm)"]},"status_code":201,"response_headers":{"Boulder-Requester":["18439569"],"Cache-Control":["public, max-age=0, no-cache"],"Content-Length":["344"],"Content-Type":["application/json"],"Date":["Sun, 07 Mar 2021 11:49:27 GMT"],"Link":["<https://acme-staging-v02.api.letsencrypt.org/directory>;rel=\"index\""],"Location":["https://acme-staging-v02.api.letsencrypt.org/acme/order/18439569/3847310"],"Replay-Nonce":["0003LxG0XCJ_Rr1hKDSdP-_6J9Y7B8Hwqwa9R9oIr-suens"],"Server":["nginx"],"Strict-Transport-Security":["max-age=604800"],"X-Frame-Options":["DENY"]}}
{"level":"debug","ts":1615117767.7458289,"logger":"tls.issuance.acme.acme_client","msg":"http request","method":"POST","url":"https://acme-staging-v02.api.letsencrypt.org/acme/authz-v3/3192511","headers":{"Content-Type":["application/jose+json"],"User-Agent":["Caddy/2.4.0-beta.1 CertMagic acmez (linux; arm)"]},"status_code":200,"response_headers":{"Boulder-Requester":["18439569"],"Cache-Control":["public, max-age=0, no-cache"],"Content-Length":["389"],"Content-Type":["application/json"],"Date":["Sun, 07 Mar 2021 11:49:27 GMT"],"Link":["<https://acme-staging-v02.api.letsencrypt.org/directory>;rel=\"index\""],"Replay-Nonce":["0004NfyLDPLQ7KQ2g4pEtEtb9TAgtuWpzY3neBfu0ZN-_vk"],"Server":["nginx"],"Strict-Transport-Security":["max-age=604800"],"X-Frame-Options":["DENY"]}}
{"level":"info","ts":1615117767.7466753,"logger":"tls.issuance.acme.acme_client","msg":"trying to solve challenge","identifier":"*.net.dbren.uk","challenge_type":"dns-01","ca":"https://acme-staging-v02.api.letsencrypt.org/directory"}
{"level":"debug","ts":1615117769.6054442,"logger":"tls.issuance.acme.acme_client","msg":"http request","method":"POST","url":"https://acme-staging-v02.api.letsencrypt.org/acme/chall-v3/3192508/YpvLVw","headers":{"Content-Type":["application/jose+json"],"User-Agent":["Caddy/2.4.0-beta.1 CertMagic acmez (linux; arm)"]},"status_code":200,"response_headers":{"Boulder-Requester":["18439568"],"Cache-Control":["public, max-age=0, no-cache"],"Content-Length":["189"],"Content-Type":["application/json"],"Date":["Sun, 07 Mar 2021 11:49:29 GMT"],"Link":["<https://acme-staging-v02.api.letsencrypt.org/directory>;rel=\"index\"","<https://acme-staging-v02.api.letsencrypt.org/acme/authz-v3/3192508>;rel=\"up\""],"Location":["https://acme-staging-v02.api.letsencrypt.org/acme/chall-v3/3192508/YpvLVw"],"Replay-Nonce":["0004ehpjgF3odZBatagvV59_lAvBbwrh1sbmsiidlLPcj6I"],"Server":["nginx"],"Strict-Transport-Security":["max-age=604800"],"X-Frame-Options":["DENY"]}}
{"level":"debug","ts":1615117769.6059616,"logger":"tls.issuance.acme.acme_client","msg":"challenge accepted","identifier":"net.dbren.uk","challenge_type":"dns-01"}
{"level":"debug","ts":1615117770.0064352,"logger":"tls.issuance.acme.acme_client","msg":"http request","method":"POST","url":"https://acme-staging-v02.api.letsencrypt.org/acme/authz-v3/3192508","headers":{"Content-Type":["application/jose+json"],"User-Agent":["Caddy/2.4.0-beta.1 CertMagic acmez (linux; arm)"]},"status_code":200,"response_headers":{"Boulder-Requester":["18439568"],"Cache-Control":["public, max-age=0, no-cache"],"Content-Length":["549"],"Content-Type":["application/json"],"Date":["Sun, 07 Mar 2021 11:49:29 GMT"],"Link":["<https://acme-staging-v02.api.letsencrypt.org/directory>;rel=\"index\""],"Replay-Nonce":["0004Muq2xlRsDSk1IGbVdnFNLvj7htHVppNBSkS3hfHLcZE"],"Server":["nginx"],"Strict-Transport-Security":["max-age=604800"],"X-Frame-Options":["DENY"]}}
{"level":"error","ts":1615117771.6162183,"logger":"tls.issuance.acme.acme_client","msg":"challenge failed","identifier":"net.dbren.uk","challenge_type":"dns-01","status_code":403,"problem_type":"urn:ietf:params:acme:error:unauthorized","error":"No TXT record found at _acme-challenge.net.dbren.uk"}
{"level":"error","ts":1615117771.6163986,"logger":"tls.issuance.acme.acme_client","msg":"validating authorization","identifier":"net.dbren.uk","error":"authorization failed: HTTP 403 urn:ietf:params:acme:error:unauthorized - No TXT record found at _acme-challenge.net.dbren.uk","order":"https://acme-staging-v02.api.letsencrypt.org/acme/order/18439568/3847307","attempt":1,"max_attempts":3}
{"level":"debug","ts":1615117772.7376325,"logger":"tls.issuance.acme.acme_client","msg":"http request","method":"POST","url":"https://acme-staging-v02.api.letsencrypt.org/acme/chall-v3/3192511/xdUB7Q","headers":{"Content-Type":["application/jose+json"],"User-Agent":["Caddy/2.4.0-beta.1 CertMagic acmez (linux; arm)"]},"status_code":200,"response_headers":{"Boulder-Requester":["18439569"],"Cache-Control":["public, max-age=0, no-cache"],"Content-Length":["189"],"Content-Type":["application/json"],"Date":["Sun, 07 Mar 2021 11:49:32 GMT"],"Link":["<https://acme-staging-v02.api.letsencrypt.org/directory>;rel=\"index\"","<https://acme-staging-v02.api.letsencrypt.org/acme/authz-v3/3192511>;rel=\"up\""],"Location":["https://acme-staging-v02.api.letsencrypt.org/acme/chall-v3/3192511/xdUB7Q"],"Replay-Nonce":["0004SpWrMNcYd2_TBK-u5i5dhwZP9xtm2pzY5gDAqkRdc1M"],"Server":["nginx"],"Strict-Transport-Security":["max-age=604800"],"X-Frame-Options":["DENY"]}}
{"level":"debug","ts":1615117772.738071,"logger":"tls.issuance.acme.acme_client","msg":"challenge accepted","identifier":"*.net.dbren.uk","challenge_type":"dns-01"}
{"level":"debug","ts":1615117772.7844148,"logger":"tls.issuance.acme.acme_client","msg":"http request","method":"POST","url":"https://acme-staging-v02.api.letsencrypt.org/acme/new-order","headers":{"Content-Type":["application/jose+json"],"User-Agent":["Caddy/2.4.0-beta.1 CertMagic acmez (linux; arm)"]},"status_code":201,"response_headers":{"Boulder-Requester":["18439568"],"Cache-Control":["public, max-age=0, no-cache"],"Content-Length":["342"],"Content-Type":["application/json"],"Date":["Sun, 07 Mar 2021 11:49:32 GMT"],"Link":["<https://acme-staging-v02.api.letsencrypt.org/directory>;rel=\"index\""],"Location":["https://acme-staging-v02.api.letsencrypt.org/acme/order/18439568/3847376"],"Replay-Nonce":["0004i0yY-8OFzWvhQD-D5si3uGM5QCyMrB_jmdBJH5arrYI"],"Server":["nginx"],"Strict-Transport-Security":["max-age=604800"],"X-Frame-Options":["DENY"]}}
{"level":"debug","ts":1615117772.9355478,"logger":"tls.issuance.acme.acme_client","msg":"http request","method":"POST","url":"https://acme-staging-v02.api.letsencrypt.org/acme/authz-v3/3192572","headers":{"Content-Type":["application/jose+json"],"User-Agent":["Caddy/2.4.0-beta.1 CertMagic acmez (linux; arm)"]},"status_code":200,"response_headers":{"Boulder-Requester":["18439568"],"Cache-Control":["public, max-age=0, no-cache"],"Content-Length":["805"],"Content-Type":["application/json"],"Date":["Sun, 07 Mar 2021 11:49:32 GMT"],"Link":["<https://acme-staging-v02.api.letsencrypt.org/directory>;rel=\"index\""],"Replay-Nonce":["0003EWDnt_SVORi44Dw_XF8eFd0YZ90f_6mmaOgoUn9qSZE"],"Server":["nginx"],"Strict-Transport-Security":["max-age=604800"],"X-Frame-Options":["DENY"]}}
{"level":"debug","ts":1615117772.9363232,"logger":"tls.issuance.acme.acme_client","msg":"no solver configured","challenge_type":"tls-alpn-01"}
{"level":"debug","ts":1615117772.9363937,"logger":"tls.issuance.acme.acme_client","msg":"no solver configured","challenge_type":"http-01"}
{"level":"debug","ts":1615117773.0875306,"logger":"tls.issuance.acme.acme_client","msg":"http request","method":"POST","url":"https://acme-staging-v02.api.letsencrypt.org/acme/authz-v3/3192572","headers":{"Content-Type":["application/jose+json"],"User-Agent":["Caddy/2.4.0-beta.1 CertMagic acmez (linux; arm)"]},"status_code":200,"response_headers":{"Boulder-Requester":["18439568"],"Cache-Control":["public, max-age=0, no-cache"],"Content-Length":["809"],"Content-Type":["application/json"],"Date":["Sun, 07 Mar 2021 11:49:33 GMT"],"Link":["<https://acme-staging-v02.api.letsencrypt.org/directory>;rel=\"index\""],"Replay-Nonce":["0003So9ZJlgXBUL02e8MjkQ8NFpmCSGDCbqPGcjbG2EKat0"],"Server":["nginx"],"Strict-Transport-Security":["max-age=604800"],"X-Frame-Options":["DENY"]}}
{"level":"info","ts":1615117773.0954053,"logger":"tls.issuance.acme","msg":"waiting on internal rate limiter","identifiers":["net.dbren.uk"]}
{"level":"info","ts":1615117773.095549,"logger":"tls.issuance.acme","msg":"done waiting on internal rate limiter","identifiers":["net.dbren.uk"]}
{"level":"debug","ts":1615117773.1351142,"logger":"tls.issuance.acme.acme_client","msg":"http request","method":"POST","url":"https://acme-staging-v02.api.letsencrypt.org/acme/authz-v3/3192511","headers":{"Content-Type":["application/jose+json"],"User-Agent":["Caddy/2.4.0-beta.1 CertMagic acmez (linux; arm)"]},"status_code":200,"response_headers":{"Boulder-Requester":["18439569"],"Cache-Control":["public, max-age=0, no-cache"],"Content-Length":["569"],"Content-Type":["application/json"],"Date":["Sun, 07 Mar 2021 11:49:33 GMT"],"Link":["<https://acme-staging-v02.api.letsencrypt.org/directory>;rel=\"index\""],"Replay-Nonce":["0003a9p8FDVJVLD5WnYX3H6EVhdpo5nkSIH9_GpzpsVhKOw"],"Server":["nginx"],"Strict-Transport-Security":["max-age=604800"],"X-Frame-Options":["DENY"]}}
{"level":"debug","ts":1615117773.6784244,"logger":"tls.issuance.acme.acme_client","msg":"http request","method":"HEAD","url":"https://acme-staging-v02.api.letsencrypt.org/acme/new-nonce","headers":{"User-Agent":["Caddy/2.4.0-beta.1 CertMagic acmez (linux; arm)"]},"status_code":200,"response_headers":{"Cache-Control":["public, max-age=0, no-cache"],"Date":["Sun, 07 Mar 2021 11:49:33 GMT"],"Link":["<https://acme-staging-v02.api.letsencrypt.org/directory>;rel=\"index\""],"Replay-Nonce":["0004UUJH3esoYg-ldc5KtraYVYGtrI4mSmNN83lXZbMQEf8"],"Server":["nginx"],"Strict-Transport-Security":["max-age=604800"],"X-Frame-Options":["DENY"]}}
{"level":"debug","ts":1615117773.8356457,"logger":"tls.issuance.acme.acme_client","msg":"http request","method":"POST","url":"https://acme-staging-v02.api.letsencrypt.org/acme/new-order","headers":{"Content-Type":["application/jose+json"],"User-Agent":["Caddy/2.4.0-beta.1 CertMagic acmez (linux; arm)"]},"status_code":201,"response_headers":{"Boulder-Requester":["18439569"],"Cache-Control":["public, max-age=0, no-cache"],"Content-Length":["342"],"Content-Type":["application/json"],"Date":["Sun, 07 Mar 2021 11:49:33 GMT"],"Link":["<https://acme-staging-v02.api.letsencrypt.org/directory>;rel=\"index\""],"Location":["https://acme-staging-v02.api.letsencrypt.org/acme/order/18439569/3847390"],"Replay-Nonce":["00041fbUE0vlmN-mmNCOeF2iSXBIw5YoegS7f3J-SlCKHc4"],"Server":["nginx"],"Strict-Transport-Security":["max-age=604800"],"X-Frame-Options":["DENY"]}}
{"level":"debug","ts":1615117773.9695787,"logger":"tls.issuance.acme.acme_client","msg":"http request","method":"POST","url":"https://acme-staging-v02.api.letsencrypt.org/acme/authz-v3/3192583","headers":{"Content-Type":["application/jose+json"],"User-Agent":["Caddy/2.4.0-beta.1 CertMagic acmez (linux; arm)"]},"status_code":200,"response_headers":{"Boulder-Requester":["18439569"],"Cache-Control":["public, max-age=0, no-cache"],"Content-Length":["805"],"Content-Type":["application/json"],"Date":["Sun, 07 Mar 2021 11:49:33 GMT"],"Link":["<https://acme-staging-v02.api.letsencrypt.org/directory>;rel=\"index\""],"Replay-Nonce":["0004pGmzChySCCQDUQj_lnIRIVJUmS-CrOEbTeLm6E6gvIk"],"Server":["nginx"],"Strict-Transport-Security":["max-age=604800"],"X-Frame-Options":["DENY"]}}
{"level":"debug","ts":1615117773.9701407,"logger":"tls.issuance.acme.acme_client","msg":"no solver configured","challenge_type":"tls-alpn-01"}
{"level":"debug","ts":1615117773.9701996,"logger":"tls.issuance.acme.acme_client","msg":"no solver configured","challenge_type":"http-01"}
{"level":"info","ts":1615117773.9702225,"logger":"tls.issuance.acme.acme_client","msg":"trying to solve challenge","identifier":"net.dbren.uk","challenge_type":"dns-01","ca":"https://acme-staging-v02.api.letsencrypt.org/directory"}
{"level":"error","ts":1615117774.1021292,"logger":"tls.issuance.acme.acme_client","msg":"challenge failed","identifier":"*.net.dbren.uk","challenge_type":"dns-01","status_code":403,"problem_type":"urn:ietf:params:acme:error:unauthorized","error":"No TXT record found at _acme-challenge.net.dbren.uk"}
{"level":"error","ts":1615117774.1023877,"logger":"tls.issuance.acme.acme_client","msg":"validating authorization","identifier":"*.net.dbren.uk","error":"authorization failed: HTTP 403 urn:ietf:params:acme:error:unauthorized - No TXT record found at _acme-challenge.net.dbren.uk","order":"https://acme-staging-v02.api.letsencrypt.org/acme/order/18439569/3847310","attempt":1,"max_attempts":3}
Cloudflare does say that the API token was used when placing my cursor over the status of the API token.
Providing the Cloudflare API token and email without environment variables (placing directly into the Caddyfile). This also did not work.
Using the Let’s Encrypt production endpoint once. Same errors occurred. Not surprising but thought it was worth a try
Increasing ACME timeout using:
issuer acme {
dns cloudflare token
timeout 600s
Is there something I have misconfigured here that somebody can spot?
One thing I did find interesting was even though I built the container image with 2.3.0
tags, the version is v2.4.0-beta.1
Something to do with using xcaddy?
Please let me know if any other information is needed.
Any help is greatly appreciated.
