Assuming a domain that you do not control is failing the SSL handshake with Caddy, will setting up the Cloudflare DNS provider module solve this considering it’s not your domain or DNS records.
For context I have a user setting a custom domain and the Cloudflare certificates conflict if the Cloudflare proxy is enabled. It’s not a big problem as I just tell them to disable the proxy, I’m just wondering if it can be solved by the module considering I don’t own the domains.
