Client TLS Certficat is not always requested http/3
TLS certificate is not always requested.
I’m using:
  • TLS client if provided
  • Fallback to basic_auth if there is no certificate.
The certificate is sent/received on the first call, but the refresh doesn’t work and it falls back to basic authentication. (I use a similar configuration on Apache without this issue).
It happens only when it switches to HTTP/3.0.
— Certificat should be send
I saw that on http/2.0 it works but not with http/3.0
Docker, caddy
Docker
b. My complete Caddy config:
example.com {
        log
                client_auth {
                        mode verify_if_given
                        trusted_ca_cert_file /etc/caddy/easy-rsa.crt
                        #trusted_pool  file /etc/caddy/easy-rsa.crt << didn't work
        @notlsauth expression {tls_client_subject} == null
        handle_path /vault/* {
                basic_auth * {
                        Bob HASH
                rewrite * /vault/{uri}
                reverse_proxy vault:80
        handle_path /git/* {
                basic_auth @notlsauth {
                        Bob HASH
                reverse_proxy gogs:3000
        respond "Hello {http.request.tls.client.subject} {uri} {http.request.tls.client.san.emails.0}"
If use a workaround:
remove globally http/3.0
    servers {
        protocols h1 h2
