Is there a way to do that in the V2 ?
Luckily, this was just merged in a couple weeks ago: ability to specify that client cert must be present in SSL by evtr · Pull Request #2913 · caddyserver/caddy · GitHub
I think we’re still missing documentation and Caddyfile support, but this should be added very soon. @matt
It’s supported via JSON configuration for now: JSON Config Structure - Caddy Documentation
The documentation when it gets implemented for the Caddyfile config will be here: tls (Caddyfile directive) — Caddy Documentation
Eh, yeah, need to polish up the docs on that feature a bit, and add Caddyfile support.
Thanks! So I will use the JSON config in the meantimes.
