Hi everyone.
I’ve been a caddy fan for a year or so, and what I liked the most was that just by using it, you get LetsEncrypt certificate management for free (initially I was using NGINX and acme tools, but it lacked the automation I wanted on that sort of stuff).
Recently I’ve hit the maximum number of certificates issued, and reading the LetsEncrypt rate limits page, I found this:
If you have a lot of subdomains, you may want to combine them into a single certificate, up to a limit of 100 Names per Certificate.
I mostly use subdomains, and after reading this, I’m thinking about having 1 domain per certificate and reusing it across subdomains.
My question is: Can Caddy manage that automatically? Or would I need to request a certificate manually and then make caddy use it with the tls
directive?
Thanks!
