No worries!
Hit us back up if it doesn’t sort itself out with time!
No worries!
FYI you don’t need to specify the ACME endpoint, it’s optional. Also if you set this, then it also turns off zerossl. So you need to also add issuer zerossl
below that to retain the issuer fallback mechanism in Caddy (strongly recommended, in case one issuer fails in an unusual event, it will have the opportunity to try a different one to recover).
This topic was automatically closed after 29 days. New replies are no longer allowed.
