I’m not using that specifically
I’ve tried like 10 things. This is just one among all those 10 things just to see that it doesn’t work either.
Obviously I started with, that was the first thing I tried…
fedora.mcamargo.es {
At this point, nothing works, I’m trying to see if I can get a little bit of more info in the logs or something because I’m 100% clueless of what’s going on…
I’ve added
To add more verbosity
caddy | {"level":"info","ts":1722861074.6596396,"msg":"serving initial configuration"}
caddy | {"level":"info","ts":1722861074.6600025,"logger":"tls.obtain","msg":"acquiring lock","identifier":"fedora.mcamargo.es"}
caddy | {"level":"info","ts":1722861074.6817706,"logger":"tls.obtain","msg":"lock acquired","identifier":"fedora.mcamargo.es"}
caddy | {"level":"info","ts":1722861074.682164,"logger":"tls.obtain","msg":"obtaining certificate","identifier":"fedora.mcamargo.es"}
caddy | {"level":"debug","ts":1722861074.6823566,"logger":"events","msg":"event","name":"cert_obtaining","id":"9e9cf94d-9f26-477d-a4cb-c5279811dc1b","origin":"tls","data":{"identifier":"fedora.mcamargo.es"}}
caddy | {"level":"debug","ts":1722861074.682894,"logger":"tls.obtain","msg":"trying issuer 1/1","issuer":"acme-v02.api.letsencrypt.org-directory"}
caddy | {"level":"info","ts":1722861074.6829708,"logger":"tls","msg":"storage cleaning happened too recently; skipping for now","storage":"FileStorage:/data/caddy","instance":"7bec2d31-f920-4348-b44a-fd5d01d128eb","try_again":1722947474.6829655,"try_again_in":86399.999999185}
caddy | {"level":"info","ts":1722861074.6831014,"logger":"tls","msg":"finished cleaning storage units"}
caddy | {"level":"info","ts":1722861074.683595,"logger":"http","msg":"waiting on internal rate limiter","identifiers":["fedora.mcamargo.es"],"ca":"https://acme-v02.api.letsencrypt.org/directory","account":""}
caddy | {"level":"info","ts":1722861074.683631,"logger":"http","msg":"done waiting on internal rate limiter","identifiers":["fedora.mcamargo.es"],"ca":"https://acme-v02.api.letsencrypt.org/directory","account":""}
caddy | {"level":"info","ts":1722861074.68369,"logger":"http","msg":"using ACME account","account_id":"https://acme-v02.api.letsencrypt.org/acme/acct/1873678947","account_contact":[]}
caddy | {"level":"debug","ts":1722861075.1663668,"logger":"http.acme_client","msg":"http request","method":"GET","url":"https://acme-v02.api.letsencrypt.org/directory","headers":{"User-Agent":["Caddy/2.8.4 CertMagic acmez (linux; amd64)"]},"response_headers":{"Cache-Control":["public, max-age=0, no-cache"],"Content-Length":["746"],"Content-Type":["application/json"],"Date":["Mon, 05 Aug 2024 12:31:15 GMT"],"Server":["nginx"],"Strict-Transport-Security":["max-age=604800"],"X-Frame-Options":["DENY"]},"status_code":200}
caddy | {"level":"debug","ts":1722861075.1668687,"logger":"http.acme_client","msg":"creating order","account":"https://acme-v02.api.letsencrypt.org/acme/acct/1873678947","identifiers":["fedora.mcamargo.es"]}
caddy | {"level":"debug","ts":1722861075.326039,"logger":"http.acme_client","msg":"http request","method":"HEAD","url":"https://acme-v02.api.letsencrypt.org/acme/new-nonce","headers":{"User-Agent":["Caddy/2.8.4 CertMagic acmez (linux; amd64)"]},"response_headers":{"Cache-Control":["public, max-age=0, no-cache"],"Date":["Mon, 05 Aug 2024 12:31:15 GMT"],"Link":["<https://acme-v02.api.letsencrypt.org/directory>;rel=\"index\""],"Replay-Nonce":["QYxeyab8DjxRsHH1sLA6jFmfoLE8S08iXhQDHfAjESgEfpn3OyE"],"Server":["nginx"],"Strict-Transport-Security":["max-age=604800"],"X-Frame-Options":["DENY"]},"status_code":200}
caddy | {"level":"debug","ts":1722861075.4871967,"logger":"http.acme_client","msg":"http request","method":"POST","url":"https://acme-v02.api.letsencrypt.org/acme/new-order","headers":{"Content-Type":["application/jose+json"],"User-Agent":["Caddy/2.8.4 CertMagic acmez (linux; amd64)"]},"response_headers":{"Boulder-Requester":["1873678947"],"Cache-Control":["public, max-age=0, no-cache"],"Content-Length":["107"],"Content-Type":["application/problem+json"],"Date":["Mon, 05 Aug 2024 12:31:15 GMT"],"Link":["<https://acme-v02.api.letsencrypt.org/directory>;rel=\"index\""],"Replay-Nonce":["VbHcGKwn7lYkfnUCTLwWWACiemiMrVlu3OWCc8QcEvD_1iiDdlY"],"Server":["nginx"]},"status_code":400}
caddy | {"level":"error","ts":1722861075.4873748,"logger":"tls.obtain","msg":"could not get certificate from issuer","identifier":"fedora.mcamargo.es","issuer":"acme-v02.api.letsencrypt.org-directory","error":"HTTP 400 urn:ietf:params:acme:error:malformed - JWS verification error"}
caddy | {"level":"debug","ts":1722861075.4875069,"logger":"events","msg":"event","name":"cert_failed","id":"0162d9bf-fed4-41e7-aa54-e9250562d8e7","origin":"tls","data":{"error":{},"identifier":"fedora.mcamargo.es","issuers":["acme-v02.api.letsencrypt.org-directory"],"renewal":false}}
caddy | {"level":"error","ts":1722861075.4875762,"logger":"tls.obtain","msg":"will retry","error":"[fedora.mcamargo.es] Obtain: [fedora.mcamargo.es] creating new order: attempt 1: https://acme-v02.api.letsencrypt.org/acme/new-order: HTTP 400 urn:ietf:params:acme:error:malformed - JWS verification error (ca=https://acme-v02.api.letsencrypt.org/directory)","attempt":1,"retrying_in":60,"elapsed":0.805740177,"max_duration":2592000}
But still I cannot see anything relevant in the logs.
