See the latest instructions here: @caddy/caddy Copr
As of April 2020:
$ yum-config-manager --add-repo https://copr.fedorainfracloud.org/coprs/g/caddy/caddy/repo/epel-7/group_caddy-caddy-epel-7.repo
$ yum install caddy
As of April 2020:
$ yum install caddy
Howdy Hendrik,
There are a few things going on here. We just added our first CentOS 8 build yesterday, and hadn’t updated the installation instructions yet (they are now). You shouldn’t expect the CentOS 7 instructions to work on CentOS 8. The yum-utils package exists on CentOS 8 for compatibility, but yum functionality on CentOS 8 is a wrapper for dnf, the same package manager used in Fedora. You can skip installing yum-utils. I can see in your screenshot that you eventually tried the correct dnf method.
FYI I edited your post because it looked partly like a typo (yum-config
instead of yum-config-manager
) and looked like using the wrong steps. Thanks for following up with proof!
Now that Carl has clarified, I’ll move this out of the Wiki category because it’s clear this was just a docs issue plus a misunderstanding - it’s better to leave the Wiki pages as evergreen content.
